Updated on 2025-04-11 GMT+08:00
Image Tag Immutability
To ensure end-to-end trust and prevent existing images from being overwritten if a set of access credentials gets leaked, you can configure an immutability policy for images in a namespace. If you attempt to push an image with a tag that is already in the namespace, an error will be returned.
Only one immutability policy can be created for each namespace.
Creating an Image Tag Immutability Policy
  1. Log in to the SWR console. In the upper left corner, switch to your region. Click your repository name.
  2. In the navigation pane, choose O&M Center > Image Tag Immutability.
  3. Click Create Immutability Policy in the upper right corner.
  4. In the displayed dialog box, configure the parameters.
    Table 1 Image tag immutability policies
    Namespace
    Namespace where an immutability policy will be created. It can be a public or private namespace.
    Application Scope
    Select one or more images in the namespace.
    Tag
    Specify the image tags that the policy will be applied to. If this parameter is omitted or set to **, the policy will be applied to all image tags.
    • For Image, you can select one or more images from the list.
    • Alternatively, you can enter a regular expression.
      The regular expression can be nginx-* or {repo1, repo2}.
      • *: matches any field that does not contain the path separator /.
      • **: matches any field that contains the path separator /.
      • ?: matches any single character except /.
      • {option 1, option 2, ...}: matches any of the options.
  5. Click OK.
Managing Image Tag Immutability Policies
You can manage your immutability policies as follows.
  • Enable or disable an immutability policy. indicates a policy is enabled and indicates the policy is disabled. A new policy is enabled by default.
  • Modify an immutability policy. All parameters except Namespace can be modified.
  • Delete an immutability policy.
