Updated on 2025-04-11 GMT+08:00
Deleting a Repository Tag
You can delete tags on the SWR or TMS console.
Deleting a Tag on the SWR Console
  1. Log in to the SWR console. In the upper left corner, switch to your region.
  2. On the repository management page, locate the repository whose tag needs to be deleted and click Manage Tag.
  3. In the Manage Tag dialog box, locate the tag to be deleted and click Delete.
Deleting Tags in a Batch on the TMS Console
  1. Log in to the TMS console.
  2. Choose Resource Tags > Tag Management, select the target region, set Resource Type to SWR, and click Search. All SWR resources in this region will be returned.
  3. Locate the repositories whose tags need to be deleted. Click Manage Tag above the list.
    Figure 1 Tag search result
  4. Locate each tag to be deleted, click Delete in the Operation column, and click OK.
    Figure 2 Managing tags
  5. (Optional) Click in the upper right corner of the Search Result area.
    The tag list is refreshed.
