Updated on 2026-08-06 GMT+08:00
Changing Disk Performance
If the disks configured for your desktop pools are General Purpose SSD V2 disks, you can change the disk performance on the console if the IOPS or throughput cannot meet service requirements.
The IOPS or throughput can only be changed for General Purpose SSD V2 disks.
You can change disk performance in the following two scenarios. Select a scenario as required.
