Cloud Eye Events Supported by Workspace
Functions
The Cloud Eye event monitoring supported by Workspace provides event data reporting, query, and alarm reporting. When there are specified events, you will receive alarm notifications from Cloud Eye.
Namespaces
SYS.Workspace
Monitored Events
Event Name |
Event ID |
Event Severity |
Event Description |
Handling Suggestion |
Impact |
Abnormal desktop heartbeat |
desktopStatusAbnormal |
Major |
The network is disconnected or the key is lost. |
The desktop cannot be accessed. |
Failure of assigning desktops in a desktop pool |
desktopPoolAssignFailed |
Major |
This fault is caused by policies. |
New desktops cannot be assigned. |
Desktop access failure |
desktopAccessFailed |
Major |
This fault is caused by VM shutdown and restart, access gateway exceptions, or network faults. |
Desktop startup failure |
desktopStartFailed |
Major |
Underlying resources are insufficient. |
Wait for a while and try again. |
Failure of automatic desktop pool capacity expansion |
desktopPoolExpandFailed |
Major |
The instance quota or underlying resources are insufficient. |
Desktop capacity cannot be expanded. |
Failure of migrating a desktop running on a dedicated host |
desktopMigrateFailed |
Major |
The host malfunctions. |
No dedicated host is available for desktop scheduling. |
Login failure |
userLoginFailed |
Major |
The client network is disconnected, or the enterprise ID, username, or password is invalid. |
The desktop or applications cannot be used. |
Screen recording failure |
screenRecordFailed |
Major |
An unknown exception occurs on the desktop. |
Screen recording malfunctions and the desktop is disconnected. |
Damaged screen recording file |
screenRecordFileDamaged |
Major |
The screen recording file is maliciously damaged. |
The screen recording file is abnormal. |
Screen recording file upload failure |
screenRecordUploadFailed |
Major |
The network between the desktop and OBS malfunctions. |
Screen recording file upload failed. |
Bypassing controlled applications |
appRestrictFailed |
Major |
The application control agent is continuously killed. |
Check whether a script is used to continuously kill the application control agent. |
Application control failed. |
Abnormal agent process |
agentAbnormal |
Major |
The agent process has been killed or reset. |
The agent process can be automatically restarted after being killed. |
Functions such as application control and upgrade will be affected. |
Abnormal desktop disconnection |
desktopAbnormalDisconnection |
Major |
The client network malfunctions or an unknown error occurs on the desktop. |
Desktop connection failed. |
