Updated on 2025-08-20 GMT+08:00
Monitoring Events of Application Management
  • An application may start earlier than the application management agent, or bypass monitoring when the application management agent is killed. To minimize the impact, you can configure an alarm rule and view alarm records on Cloud Eye to get real-time notifications of monitoring events. For details, see Alarms.
  • Table 1 describes the monitoring events of application management.
Table 1 Monitoring events
Event Source
Dimension (Mandatory for Specified Resources)
Event ID
Event Name
Event Severity
Event Description
Handling Suggestion
Event Impact
agentAbnormal
Abnormal agent process
Major
The agent process has been killed or reset.
The agent process can be automatically restarted after being killed.
Functions such as application management and upgrade will be affected.
appRestrictFailed
Bypassing controlled applications
Major
The application management agent is continuously killed.
Check whether a script is used to continuously kill the application management agent.
Application management failed.
For alarm policy configuration, the events Bypassing controlled applications and Abnormal agent process are available only for HDA 25.1.0 or later.
