Updated on 2025-08-20 GMT+08:00
Screen Capture on the Login Page
You can configure whether to allow screen capture after login from an Android client on the Tenant Configuration page.
  1. Log in to the console.
  2. In the navigation pane, choose Tenant Configuration > Basic Settings.
    The Basic Settings page is displayed.
  3. In the Other area on the Basic Settings page, determine whether to enable Screen Capture on Login Page.
    • Enabled: Screen capture is allowed after login from an Android client.
      Click Enable. In the displayed dialog box, click OK.
    • Disabled: Screen capture is not allowed after login from an Android client.
      Click Disable. In the displayed dialog box, click OK.
    Only Android clients of 24.6.4 and later versions support this function.
