Updated on 2026-02-24 GMT+08:00
User Name Prefixes
You can configure the username prefix for a Linux desktop in Tenant Configuration.
  1. Log in to the console.
  2. In the navigation pane, choose Tenant Configuration > Basic Settings.
    The Basic Settings page is displayed.
  3. In the Other area on the Basic Settings page, determine whether to enable username prefix.
    • Enabled: The username prefix takes effect only for Linux desktops and digit-only usernames.
      Click Enable and enter a prefix in letters. Click OK.
      After the username prefix is enabled, you can click Modify next to Prefix to modify the prefix. Then click OK.
    • Disabled: No username prefix is used.
      Click Disable and then click OK.
