Cloud Desktop Statuses
The following status fields are returned by the Workspace API for querying desktop details:
- status: power supply status of a desktop
- task_status: task status of a desktop, that is, the intermediate status of a desktop when the desktop is processing an operation
- login_status: connection status of a desktop
- Running status: consists of task_status and status. If task_status is not empty, its status value is displayed. If task_status is empty, the status value of status is displayed.
- Connection status: consists of login_status. Table 3 describes each status in detail and the status values displayed on the console.
Table 1 status list status
ACTIVE
Running
SHUTOFF
Stopped
HIBERNATED
Hibernated
ERROR
Faulty
STARTING
Starting
STOPPING
Stopping
RESTARTING
Restarting
HIBERNATING
Hibernating
AWAKENING
Waking up
Table 2 task_status list task_status
CreatedSuccess
Created
creating
Creating
Deleting
Deleting
updating
Rebuilding
attaching
Assigning a desktop to a user
DesktopDetaching
Unbinding a user
desktopNetworkChanging
Changing the network
userPrivilegeGroupChanging
Changing the user permission group
migrating
Cold migrating
updatingSids
Updating the SID
rejoiningDomain
Rejoining the domain
restoring
Restoring a desktop
addingVolumes
Adding a disk
deletingVolumes
Deleting a disk
expandingVolumes
Expanding disk capacity
desktopToImage
Creating an image
acrossAzDesktopMigrating
Migrating across AZs
desktopResizing
Changing specifications
creatingWksSnapshot
Creating a snapshot
restoringWksSnapshot
Restoring a snapshot
Table 3 login_status list login_status
Connection Status Displayed on the Console (New Version)
Connection Status Displayed on the Console (Old Version)
CONNECTED
The user is connecting to a desktop.
Connected
In use
DISCONNECTED
The user has disconnected from a desktop after using it.
Unconnected
Disconnected
REGISTERED
The desktop is ready after being started.
Ready
OFFLINE
The desktop is offline because it is stopped or hibernated.
Offline
UNREGISTER
The desktop cannot be connected to temporarily due to abnormal registration status. If there is an ongoing task, wait until the task is completed and then check the status. If the connection cannot be established for a long time, you can remotely log in to check the issue or restart the desktop.
Connection failed
Connection failed
