Monitoring Metrics Reported by Workspace to Cloud Eye
Functions
This section describes the monitoring metrics reported by Workspace to Cloud Eye and defines the namespace for the metrics. You can use Cloud Eye to query metrics and alarms generated by Workspace.
Namespaces
SYS.Workspace
Supported Metrics
The supported metrics vary with desktop OSs. See Table 1. (√: supported; x: unsupported)
Table 2 describes these metrics.
Metric ID |
Metrics Name |
Description |
Value Range |
Unit |
Number System |
Monitored Object (Dimension) |
Monitoring Interval (Raw Data) |
cpu_util |
CPU Usage |
This metric is used to show the CPU usage of a desktop. Formula: CPU usage of a desktop/Number of vCPUs in the desktop |
0-100 |
N/A |
Cloud desktop |
5 min |
mem_util |
Memory Usage |
This metric is used to show the memory usage of a desktop. Formula: Used memory of a desktop/Total memory of the desktop |
0-100 |
N/A |
Cloud desktop |
5 min |
disk_util_inband |
Disk Usage |
This metric is used to show the disk usage of a desktop. Formula: Used disk capacity of a desktop/Total disk capacity of the desktop |
0-100 |
N/A |
Cloud desktop |
5 min |
disk_read_bytes_rate |
Disk Read Bandwidth |
This metric is used to show the data volume read from a desktop per second. Formula: Total number of bytes read from a desktop disk/Monitoring interval byte_out = (rd_bytes - last_rd_bytes)/Time difference |
≥ 0 |
Byte/s |
1024(IEC) |
Cloud desktop |
5 min |
disk_write_bytes_rate |
Disk Write Bandwidth |
This metric is used to show the data volume written to a desktop per second. Formula: Total number of bytes written to a desktop disk/Monitoring interval |
≥ 0 |
Byte/s |
1024(IEC) |
Cloud desktop |
5 min |
disk_read_requests_rate |
Disk Read IOPS |
This metric is used to show the number of read requests sent to a desktop per second. Formula: Total number of read requests sent to a desktop/Monitoring interval req_out = (rd_req - last_rd_req)/Time difference |
≥ 0 |
Request/s |
N/A |
Cloud desktop |
5 min |
disk_write_requests_rate |
Disk Write IOPS |
This metric is used to show the number of write requests sent to a desktop per second. Formula: Total number of write requests sent to a desktop/Monitoring interval req_in = (wr_req - last_wr_req)/Time difference |
≥ 0 |
Request/s |
N/A |
Cloud desktop |
5 min |
network_incoming_bytes_rate_inband |
Inband Incoming Rate |
This metric is used to show the number of incoming bytes on a desktop per second. Formula: Total number of inband incoming bytes on a desktop/Monitoring interval |
≥ 0 |
Byte/s |
1024(IEC) |
Cloud desktop |
5 min |
network_outgoing_bytes_rate_inband |
Inband Outgoing Rate |
This metric is used to show the number of outgoing bytes on a desktop per second. Formula: Total number of inband outgoing bytes on a desktop/Monitoring interval |
≥ 0 |
Byte/s |
1024(IEC) |
Cloud desktop |
5 min |
network_incoming_bytes_aggregate_rate |
Outband Incoming Rate |
This metric is used to show the number of incoming bytes on a desktop per second on the hypervisor. Formula: Total number of outband incoming bytes on a desktop/Monitoring interval |
≥ 0 |
Byte/s |
1024(IEC) |
Cloud desktop |
5 min |
network_outgoing_bytes_aggregate_rate |
Outband Outgoing Rate |
This metric is used to show the number of outgoing bytes on a desktop per second on the hypervisor. Formula: Total number of outband outgoing bytes on a desktop/Monitoring interval |
≥ 0 |
Byte/s |
1024(IEC) |
Cloud desktop |
5 min |
Dimensions
Key |
Value |
instance_id |
Desktop ID |
