Workspace O&M Monitoring Metrics
Functions
Table 1 describes the O&M monitoring metrics of Workspace.
Metric ID |
Metrics Name |
Description |
Dimension |
Example Value (By Dimension) |
Statistical Type (Calculation Method of the Return Value Queried by the /metric Interface) |
Statistical Period |
Max Query Time Range |
Max Data Retention Duration |
Metric Usage |
desktopUsage |
Desktop usage |
Proportion of the number of used desktops to the total number of desktops. Unit: percentage (%) |
Project |
No need to transfer value separately |
Average value |
1 hour or 1 day |
30 days |
180 days |
Metric query supported |
dailyUserOnlineRate |
Daily user usage |
User usage within a specified period. Unit: percentage (%) |
Project |
Average value |
1 day |
30 days |
180 days |
desktopUseNumber |
Number of used desktops |
Number of desktops used in a specified period. Statistics of each desktop are collected only once. Unit: per desktop |
Project |
Latest value |
1 hour or 1 day |
30 days |
180 days |
desktop_num_per_project |
Total number of desktops |
Total number of desktops in a project. Unit: per desktop |
Project |
Latest value |
1 hour or 1 day |
30 days |
180 days |
excellent_network_rtt_num |
Number of sessions with excellent network performance |
Number of sessions whose network latency is within 30 ms. Unit: per session |
Project |
Latest value |
1 hour |
30 days |
180 days |
Metric trend query supported |
good_network_rtt_num |
Number of sessions with good network performance |
Number of sessions whose network latency is between 31 to 50 ms. Unit: per session |
Project |
Latest value |
1 hour |
30 days |
180 days |
average_network_rtt_num |
Number of sessions with average network performance |
Number of sessions whose network latency is between 51 to 100 ms. Unit: per session |
Project |
Latest value |
1 hour |
30 days |
180 days |
poor_network_rtt_num |
Number of sessions with poor network performance |
Number of sessions whose network latency is higher than 100 ms. Unit: per session |
Project |
Latest value |
1 hour |
30 days |
180 days |
up_bandwidth |
Uplink traffic |
Traffic sent when using cloud desktops. Unit: byte |
Login session |
dim.0=transaction_id,TID-15171242896-1ca01b00014641e |
Session-level metrics do not have statistics. Only the trend can be viewed. |
1 minute |
7 days |
7 days |
down_bandwidth |
Downlink traffic |
Traffic received when using cloud desktops. Unit: byte |
Login session |
1 minute |
7 days |
7 days |
network_rtt |
Network latency |
Data transmission latency when using cloud desktops. Unit: ms |
Login session |
1 minute |
7 days |
7 days |
network_jitter |
Network jitter |
Time difference between the maximum network latency and the minimum network latency when using cloud desktops. Unit: ms |
Login session |
1 minute |
7 days |
7 days |
network_loss |
Network packet loss rate |
Ratio of the number of lost packets to the number of sent packets during the network test. Unit: percentage (%) |
Login session |
1 minute |
7 days |
7 days |
