Updated on 2025-08-20 GMT+08:00
Scheduled Task Management
This section describes how to add, delete, or modify a scheduled task on the console.
A scheduled task has been created.
Enabling or disabling a scheduled task
  1. Log in to the console.
  2. In the navigation pane, choose Tasks > Scheduled Tasks.
    The Scheduled Tasks page is displayed.
  3. In the task list, toggle on or off the switch in the Enabled or Not column of the desired scheduled task.
    • indicates that the scheduled task has been enabled.
    • indicates that the scheduled task has been disabled.
Checking the execution log of a scheduled task
  1. Click Log Details in the Execution Log column of the desired scheduled task.
  2. On the Execution Log Details page displayed, you can check the Execution Time, Task Type, Execution Interval, Task Execution Status, and Successes/Failures of the scheduled task.
    Click Export to export execution log details.
Modifying a scheduled task
  1. Click Modify in the Operation column of the desired scheduled task.
  2. You can modify parameters such as Task Name, Execution Interval, Time Zone, Time, Description (Optional), Add Script, and Timeout.
    You can click Add Script to add or deselect scripts.
  3. Select I've checked. No problem. and go to the next step: configuring execution.
  4. On the page displayed, you can modify the Execution Policy and Gray Rule parameters.
    You can click Batch Set to determine whether the script is executed in the first batch.
  5. If you want to perform this operation, enter YES or click Auto Enter.
  6. Click OK.
Modifying the execution objects of a scheduled task
  1. Choose More > Modify Object in the Operation column of the desired scheduled task.
  2. Modify the objects as required and click OK.
Copying a scheduled task
  1. Choose More > Copy in the Operation column of the desired scheduled task.
  2. Specify Task Name and Description and click OK.
Deleting a scheduled task
  1. You can delete one scheduled task or batch delete multiple scheduled tasks.
    • To delete one scheduled task, perform 17 to 18.
    • To batch delete multiple scheduled tasks, perform 19 to 21.
  2. Choose More > Delete in the Operation column of the desired scheduled task. The page for deleting a scheduled task is displayed.
  3. Click OK.
  4. Select the scheduled tasks to be deleted and click Delete above the list.
  6. Click OK.
