Enabling Collaboration
After collaboration is enabled, you can quickly initiate collaboration between desktops to improve work efficiency.
- To enable or disable collaboration, configure a whitelist by submitting a service ticket.
- Only yearly/monthly Windows cloud desktops are supported.
- Supported servers: 23.8.1 or later.
- Supported clients: 23.8.1 or later.
- Collaboration is available only in full-screen mode.
- In the navigation pane, choose Desktops > Desktops.
The Desktops page is displayed.
- Enable collaboration for desktops:
- Click More in the Operation column of the desired desktop and choose Users > Enable Collaboration.
- On the page displayed, select Enable for Collaboration, select Specifications, and click OK.
- Select multiple desktops for which collaboration is to be enabled. Click More in the upper left corner and choose Users > Enable Collaboration.
- On the page displayed, configure parameters.
- Billing Mode: Yearly/Monthly
- Processor:
- CPU: 6-party collaborative resource-Standard edition
- GPU: 6-party collaborative resource-Advanced edition
- OS: Windows
Only desktops with the same billing mode, processor, and OS can change collaborative resources in batches.
- Click OK.
- The page for purchasing collaboration is displayed.
- Check data in Cloud Service Orders.
- After you select a payment method and pay for your order, the purchase has been completed.
