Updated on 2026-09-21 GMT+08:00
Desktop Naming Rules
Create a desktop naming rule in Other.
  1. Log in to the console.
  2. In the navigation pane, choose Tenant Configuration > Other.
    The Other page is displayed.
Creating a desktop naming rule
  1. Under the Desktop Naming Rules tab, click Create Desktop Naming Rule in the upper right corner. The Create Desktop Naming Rule page is displayed.
  2. See Table 1 to create a desktop naming rule.
    Table 1 Desktop naming rules
    Example Value
    Naming Rule Name
    A desktop naming rule can contain 1 to 30 characters in only letters, digits, and underscores (_), and must start with a letter or underscore (_).
    Username
    • Included: A naming rule contains the name prefix and username and is not applicable to desktop pools.
    • Not included: A naming rule contains only the name prefix and applies to all scenarios.
    Name Prefix
    A name prefix can contain 1 to 14 characters in only letters, digits, and hyphens (-), and must start with a letter or digit.
    Username included: A + Username + B + 1
    Username not included: A + 1
    Number of Digits
    The value range is 1 to 5.
    Start Value
    The start value is related to the number of digits. If Number of Digits is 1, the start value ranges from 1 to 9. If Number of Digits is 2, the start value ranges from 1 to 99. If Number of Digits is 5, the start value ranges from 1 to 99999. That is, the maximum Number of Digits of the start value is the value of Number of Digits.
    Increment for One Username
    • Yes: The value of Number of Digits increases in ascending order based on the sequence in which desktops are assigned to a single user.
    • No: The value of Number of Digits increases in ascending order based on the assignment sequence of all desktops.
      If Username is set to Not included, Increment for One Username is not available.
    For example, let's assume that Number of Digits is 3 and Start Value is 1; and the second and eighth desktops are assigned to User A. When this parameter is set to Yes, the desktop names are UserA001 and UserA002. When this parameter is set to No, the desktop names are UserA002 and UserA008.
  1. Click OK.
Modifying a desktop naming rule
  1. Under the Desktop Naming Rules tab, click Edit in the Operation column of the desired naming rule. The Modify Desktop Naming Rule page is displayed.
  2. Modify the desktop naming rule.
    • Naming Rule Name
    • Username
    • Name Prefix
    • Number of Digits
    • Start Value
    • Increment for One Username
  3. Click OK.
Deleting a desktop naming rule
  1. Under the Desktop Naming Rules tab, click Delete in the Operation column of the desired naming rule. The Delete Desktop Naming Rule page is displayed.
  2. Click OK.
Setting a naming rule to a default one
  1. Under the Desktop Naming Rules tab, click Set as Default in the Operation column of the desired naming rule. The Default icon will be displayed on the right of the naming rule.
