Updated on 2026-10-10 GMT+08:00
Ports Supported by WAF
WAF can protect standard and non-standard ports. When you add a website to WAF, you need to specify protection port, which is your service port. WAF will then forward and protect traffic over this port. This section describes the standard and non-standard ports WAF can protect.
For example, as shown in Table 1, a cloud WAF instance from the standard edition or later and dedicated WAF instances can protect port 9001 over HTTP. If you want to protect port 9001, you can use either a cloud WAF instance from the standard edition or later or a dedicated WAF instance. Then, configure the instance in Connecting Your Website to WAF Using Cloud CNAME Access by referring to Figure 1.
Figure 1 Port configuration
Note that the supported ports may differ depending on regions.
Standard Ports
WAF can protect the following standard ports.
  • Port reserved for HTTP traffic: 80
  • Ports reserved for HTTPS traffic: 443
Non-standard ports
WAF can protect non-standard ports in addition to standard ports 80 and 443. Non-standard ports WAF can protect are slightly different depending on WAF modes.
Cloud WAF can protect many non-standard ports. Note that these non-standard ports are specified by WAF not the ports you use for your services. Which non-standard ports can be protected by WAF depends on WAF editions you are using.
Table 1 Non-standard ports that can be protected by cloud WAF
Edition
Non-standard Port That Can Be Protected
HTTP
HTTPS
Standard (pay-per-use)
81, 82, 83, 84, 86, 87, 88, 89, 800, 808, 1091, 1092, 5000, 7009, 8000, 8001, 8002, 8003, 8008, 8009, 8010, 8011, 8012, 8013, 8014, 8015, 8016, 8017, 8020, 8021, 8022, 8025, 8026, 8070, 8077, 8078, 8080, 8085, 8086, 8087, 8088, 8089, 8090, 8091, 8092, 8093, 8094, 8095, 8096, 8097, 8098, 8106, 8118, 8181, 8334, 8336, 8686, 8800, 8888, 8889, 8999, 18085, and 9001
4443, 5048, 5049, 5443, 6443, 7072, 7073, 7443, 8033, 8081, 8082, 8083, 8084, 8443, 8712, 8803, 8804, 8805, 8843, 9443, 8553, 8663, 9553, 9663, 18000, 18110, 18381, 18443, 18980,19000, and 28443
Professional
The requirements for 81, 82, 83, 84, 85, 86, 87, 88, 89, 97, 133, 134, 140, 141, 144, 151, 800, 808, 881, 888, 1000, 1090, 1091, 1092, 1135, 1139, 1180, 1688, 3128, 3333, 3501, 3601, 4444, 5000, 5001, 5080, 55222, 5555, 5601, 6001, 6666, 6699, 6788, 6789, 6842, 6868, 6969, 7000, 7001, 7002, 7003, 7004, 7005, 7006, 7009, 7010, 7011, 7012, 7013, 7014, 7015, 7016, 7018, 7019, 7020, 7021, 7022, 7023, 7024, 7025, 7026, 7070, 7080, 77081, 7082, 7083, 7088, 7097, 7510, 7777, 7800, 7979, 8000, 8001, 8002, 8003, 8004, 8007, 8008, 8009, 8010, 8011, 8012, 8013, 8014, 8015, 8016, 8017, 8020, 8021, 8022, 8024, 8025, 8026, 8070, 8077, 8078, 8080, 8085, 8086, 8087, 8088, 8089, 8090, 8091, 8092, 8093, 8094, 8095, 8096, 8097, 8098, 8106, 8118, 8181, 8182, 8232, 8334, 8336, 8686, 8800, 8813, 8814, 8888, 8889, 8989, 8999, 9000, 9001, 9002, 9003, 9007, 9020, 9021, 9022, 9023, 9024, 9025, 9026, 9027, 9028, 9029, 9037, 9050, 9077, 9080, 9081, 9082, 9083, 9084, 9085, 9086, 9087, 9088, 9089, 9099, 9180, 9200, 9201, 9205, 9207, 9208, 9209, 9210, 9211, 9212, 9213, 9802, 9898, 9908, 9916, 9918, 9919, 9928, 9929, 9939, 9945, 9770, 10000, 10001, 10080, 10087, 11000, 12601, 13000, 14000, 18080, 18085, 18081, 18180, 18280, 19101, 19501, 21028, 23333, 27777, 28080, 30002, 30086, 33332, 33334, 33702, 40010, 48299, 48800, 52725, 52726, 60008, 60010, 1091, 1092
The 90, 447, 882, 1446, 1448, 1451, 1452, 1818, 4006, 4430, 4433, 4443, 5048, 5049, 5100, 5443, 6022, 6130, 6133, 6140, 6141, 6142, 6150, 6443, 7072, 7073, 7443, 8033, 8043, 8079, 8081, 8082, 8083, 8084, 8211, 8221, 8224, 8231, 8243, 8244, 8281, 8443, 8445, 8553, 8663, 8712, 8750, 8803, 8804, 8805, 8810, 8815, 8817, 8836, 8838, 8840, 8842, 8843, 8990, 8991, 9005, 9053, 9090, 9300, 9443, 9553, 9663, 9681, 9682, 9999, 10002, 10003, 10006, 10300, 10301, 11001, 11003, 12340, 12341, 12342, 12343, 12344, 12345, 12346, 12347, 12348, 12349, 12350, 12351, 12352, 12353, 12354, 13001, 13003, 13080, 14003, 14443, 17618, 17718, 17818, 17918, 18000, 18001, 18010, 18110, 18381, 18443, 18980, 19000, 19999, 20000, 28443, 60009, 9166, 6091, 6200, 9309, 6019, 6017, 6018, 6020, 6030, 9805, 9806, 9807, 9808
Enterprise
81, 82, 83, 84, 85, 86, 87, 88, 89, 97, 133, 134, 140, 141, 144, 151, 800, 808, 881, 888, 1000, 1090, 1091, 1092, 1135, 1139, 1688, 1180, 3128, 3333, 3501, 3601, 4444, 5000, 5001, 5080, 5222, 5555, 5601, 6001, 6666, 6699, 6788, 6789, 6842, 6868, 6969, 7000, 7001, 7002, 7003, 7004, 7005, 7006, 7009, 7010, 7011, 7012, 7013, 7014, 7015, 7016, 7018, 7019, 7020, 7021, 7022, 7023, 7024, 7025, 7026, 7070, 7081, 7082, 7083, 7088, 7097, 7510, 7777, 7800, 7979, 8000, 8001, 8002, 8003, 8004, 8006, 8007, 8008, 8009, 8010, 8011, 8012, 8013, 8014, 8015, 8016, 8017, 8020, 8021, 8022, 8024, 8025, 8026, 8070, 8077, 8078, 8080, 8085, 8086, 8087, 8088, 8089, 8090, 8091, 8092, 8093, 8094, 8095, 8096, 8097, 8098, 8106, 8118, 8181, 8182, 8232, 8334, 8336, 8686, 8800, 8813, 8814, 8888, 8889, 8899, 8989, 8999, 9000, 9001, 9002, 9003, 9007, 9020, 9021, 9022, 9023, 9024, 9025, 9026, 9027, 9028, 9029, 9037, 9050, 9077, 9080, 9081, 9082, 9099, 9180, 9200, 9201, 9205, 9207, 9208, 9209, 9210, 9211, 9212, 9213, 9770, 9802, 9898, 9908, 9916, 9918, 9919, 9928, 9929, 9939, 9945, 10000, 10001, 10080, 10087, 11000, 12601, 13000, 14000, 18080, 18081, 18180, 18085, 18280, 23333, 27777, 28080, 30086, 33702, 48299, 48800
90, 447, 882, 1446, 1448, 1451, 1452, 1818, 4006, 4430, 4433, 4443, 5048, 5049, 5443, 6022, 6130, 6133, 6140, 6141, 6142, 6150, 6443, 7072, 7073, 7443, 8033, 8043, 8079, 8081, 8082, 8083, 8084, 8211, 8221, 8224, 8231, 8243, 8244, 8281, 8443, 8445, 8553, 8663, 8712, 8750, 8803, 8804, 8805, 8810, 8815, 8817, 8836, 8838, 8840, 8842, 8843, 8848, 8910, 8920, 8950, 8990, 8991, 9005, 9053, 9090, 9182, 9184, 9190, 9300, 9443, 9553, 9663, 9681, 9682, 9999, 10002, 10003, 10006, 10300, 10301, 11001, 11003, 12340, 12341, 12342, 12343, 12344, 12345, 12346, 12347, 12348, 12349, 12350, 12351, 12352, 12353, 12354, 13001, 13003, 13080, 14003, 17618, 17718, 17818, 17918, 18000, 18001, 18010, 18110, 18381, 18443, 18980, 19000, 19999, 28443, 60009, 9166, 6091, 6200, 9309, 6019, 6017, 6018, 6020, 6030, 9805, 9806, 9807, 980818088, 12590, 9091, 18019
If you use dedicated WAF instances, you can select any non-standard ports listed in Table 2.
Table 2 Non-standard ports that can be protected by dedicated WAF instances
HTTP
HTTPS
81, 82, 83, 84, 86, 87, 88, 89, 97, 800, 808, 1000, 1090, 3128, 3333, 3501, 3601, 4444, 5000, 5080, 5222, 5555, 5601, 6001, 6666, 6699, 6788, 6789, 6842, 6868, 6969, 7000, 7001, 7002, 7003, 7004, 7005, 7006, 7009, 7010, 7011, 7012, 7013, 7014, 7015, 7016, 7018, 7019, 7020, 7021, 7022, 7023, 7024, 7025, 7026, 7070, 7080, 7081, 7082, 7083, 7088, 7097, 7510, 7777, 7800, 7979, 8000, 8001, 8002, 8003, 8008, 8009, 8010, 8011, 8012, 8013, 8014, 8015, 8016, 8017, 8020, 8021, 8022, 8025, 8026, 8070, 8077, 8078, 8080, 8085, 8086, 8087, 8088, 8089, 8090, 8091, 8092, 8093, 8094, 8095, 8096, 8097, 8098, 8106, 8118, 8181, 8334, 8336, 8686, 8800, 8888, 8889, 8989, 8999, 9000, 9001, 9002, 9003, 9021, 9023, 9027, 9037, 9080, 9081, 9082, 9083, 9084, 9085, 9086, 9087, 9088, 9089, 9180, 9200, 9201, 9205, 9207, 9208, 9209, 9210, 9211, 9212, 9213, 9770, 9802, 9945, 9898, 9908, 9916, 9918, 9919, 9928, 9929, 9939, 10000, 10001, 10080, 12601, 19101, 19501, 19998, 21028, 28080, 30002, 33332, 33334, 33702, 40010, 48800, 52725, 52726, 1091, 1092, 60008, and 60010
4443, 5443, 6443, 7072, 7073, 7443, 8033, 8081, 8082, 8083, 8084, 8443, 8445, 8553, 8663, 8712, 8750, 8803, 8804, 8805, 8843, 9443, 9553, 9663, 9999, 18000, 18010, 18110, 18381, 18443, 18980, and 19000, 28443
