Changing the Protection Policy for a Protected Website
This topic walks you through how to change the protection policy used for a website.
You have used a protection policy for a website. For details, see Creating or Managing Protection Policies.
In Cloud Mode - CNAME access mode, only the professional and enterprise editions support changing the protection policy for a website.
- Log in to the WAF console.
- Click
in the upper left corner and select a region or project. - (Optional) If you have enabled the enterprise project function, in the upper part of the navigation pane on the left, select your enterprise project from the Filter by enterprise project drop-down list. Then, WAF will display the related security data in the enterprise project on the page.
- In the navigation pane on the left, click Website Settings.
- On the Website Settings page, click the target website domain name.
- In the Advanced Settings area, click Modify in the Policy column. In the dialog box displayed, select a policy and click OK.
