Help Center/ Web Application Firewall/ User Guide/ Configuring Protection Policies/ Configuring Intelligent Access Control Rules to Accurately Defend Against CC Attacks
If you enable intelligent access control, WAF uses built-in AI-powered models to analyze traffic to your website, identify CC attacks and abnormal features in HTTP requests on the origin server, and generate specific precise protection and access control rules for your website. In this way, WAF can then automatically protect your website from CC attacks.
NOTICE:
The intelligent access control protection is now available for open beta test (OBT). To enable it, submit a service ticket.
  • In cloud mode, intelligent access control rules are supported by professional and platinum editions only.
  • Intelligent access control protection is available in North China regions only.
  • The intelligent access control rules have the lowest priority.
  • When you add a website through Cloud Mode - Load balancer and set Frontend Protocol of the listener of your ELB load balancer to TCP, UDP, or QUIC, this type of rule does not take effect.
  • Disabling CC Attack Protection Rule in intelligent access control will delete all CC attack protection rules generated intelligently.
  • Disabling Precise Protection Rule in intelligent access control will delete all precise protection rule generated intelligently.
  2. Click in the upper left corner of the management console and select a region or project.
  3. Click in the upper left corner and choose Web Application Firewall under Security & Compliance.
  4. In the navigation pane on the left, choose Policies.
  5. Click the name of the target policy to go to the protection configuration page.
  6. Click the Intelligent Access Control configuration area and toggle it on or off if needed.
    • : enabled.
    • : disabled.
  7. Click Intelligent Threat Access Control. On the displayed page, configure parameters by referring to Table 1.
    Figure 1 Configure WAF Rule
    Table 1 Parameters for generating an intelligent rule
    Rule
    Action
    Protective actions Log only, Block, and JS Challenge are supported.
    • Log only: WAF only logs detected attacks.
    • Block: WAF blocks and logs detected attacks.
    • JS Challenge: WAF returns a piece of JavaScript code that can be automatically executed by a normal browser to the client. If the client properly executes the JavaScript code, WAF allows all requests from the client within a period of time (30 minutes by default). During this period, no verification is required. If the client fails to execute the code, WAF blocks the requests.
      If the referer in the request is different from the current host, the JS challenge does not work.
    Maximum Age
    When the attack stops, WAF will delete this rule after this amount of time has passed.
    Action
    Protective actions Log only and Block are supported.
    Maximum Age
    Intelligent Dynamic Rate Limit
    Protective Action
    Protection Level
    If WAF blocks normal website requests, you can change the protection level. If you select the loose level, there will be fewer false positives, but also more false negatives. If you select the tight level, the opposite is true.
    Three levels are supported: Loose, Normal, Tight.
    Minimum Threshold
    • The request traffic will be limited based on the minimum threshold or the learned baseline rate, whichever is larger. If the learned baseline rate is smaller than the number you set for Minimum Threshold, WAF limits request traffic based on the minimum threshold you set.
    • If the learned baseline rate is greater than the number you set for Minimum Threshold, WAF limits the request traffic based on the learned baseline rate.
  8. Click OK.
    You can click View WAF Rule to check the protection rules automatically generated by WAF after it detects CC attacks.
