Modifying or Deleting a Blacklist or Whitelist IP Address Group
This topic describes how to modify or delete an IP address group.
Only address groups not used by any rules can be deleted. Before you delete an address group that is being used by a blacklist or whitelist rule, remove the address group from the rule first.
- Log in to the WAF console.
- Click
in the upper left corner and select a region or project. - (Optional) If you have enabled the enterprise project function, in the upper part of the navigation pane on the left, select your enterprise project from the Filter by enterprise project drop-down list. Then, WAF will display the related security data in the enterprise project on the page.
- In the navigation pane on the left, choose .
- Click the My Address Groups tab.
- In the address group list, view the address group information.
Table 1 Parameter description Parameter
Group Name
Address group name you configured.
You can click
next to an address group name to modify the address group name.IP Addresses/Ranges
The number of IP addresses or IP address ranges added to the address group.
Rule
Rules that are using the address group.
Supplementary information about the address group.
- Modify or delete an IP address group.
- Modify an IP address or IP address range.
In the row containing the address group you want to modify, click Change IP Address/Range in the Operation column. In the dialog box displayed, add a new IP address/range and click Confirm. You can also click Delete to remove an IP address or IP address range.
- Modify an address group.
In the row containing the target address group, click Modify Address Group in the Operation column. On the Address Group Details panel displayed, you can modify the address group name and description, add an IP address or IP address range, modify the IP address or IP address range description, or delete an IP address or IP address range. You can also export or copy all IP addresses in the address group.
- Delete an address group.
In the row containing the address group you want to delete, click in the Operation column. In the displayed dialog box, click OK.
