Help Center/ Web Application Firewall/ User Guide/ Configuring Protection Policies/ Adding Rules to One or More Policies
Updated on 2026-03-05 GMT+08:00
This topic describes how to add rules to one or more policies.
If Enterprise Project is set to All projects, no rules can be added to a policy.
- Log in to the WAF console.
- Click
in the upper left corner and select a region or project. - (Optional) If you have enabled the enterprise project function, in the upper part of the navigation pane on the left, select your enterprise project from the Filter by enterprise project drop-down list. Then, WAF will display the related security data in the enterprise project on the page.
- In the navigation pane on the left, choose Policies.
- Above the policy list, click View All Policies & Rules.
- In the upper left corner above a list of a type of rule, click Add Rule.
- Select one or more policies from the Policies drop-down list.
- Set other parameters in addition to Policies.
- To add a CC attack protection rule, see Table 1.
- To add a precise protection rule, see Table 1.
- To add a blacklist or whitelist rule, see Table 1.
- To add a geolocation access control rule, see Table 1.
- To add a WTP rule, see Table 1.
- To add an information leakage prevention rule, see Table 1.
- To add a global protection whitelist rule, see Table 1.
- To add a data masking rule, see Table 1.
- Click OK.
Related Operations
- After a rule is added, the rule is Enabled by default. To disable it, click Disable in the Operation column of the target rule. You can also select multiple rules and click Disable above the rule list to disable them all together.
- To modify a rule, locate the row that contains the rule and click Modify in the Operation column. You can also select multiple rules and click Modify above the list to modify them all together.
- To delete a rule, locate the row that contains the rule and click Delete in the Operation column. You can also select multiple rules and click Delete above the list to delete them all together.
- To enable multiple rules, select them and click Enable above the list.
