Help Center/ Web Application Firewall/ User Guide/ Protection Configuration/ Configuring Core Protection Rules/ Configuring Information Leakage Prevention Rules to Protect Sensitive Information from Leakage
Updated on 2026-10-10 GMT+08:00
You can add two types of information leakage prevention rules.
  • Sensitive information filtering: prevents disclosure of sensitive information, such as ID numbers, phone numbers 11-digit phone numbers registered in China, and email addresses.
  • Response code interception: blocks the specified HTTP status codes.
Item
Constraint
Access mode and edition restrictions
  • Cloud CNAME/Cloud load balancer access: This function is only supported in professional and enterprise editions.
  • Cloud load balancer access: This function is not supported.
  • Dedicated mode: This function is supported.
Rule effective time
It takes several minutes for a new rule to take effect. After a rule takes effect, protection events triggered by the rule will be displayed on the Events page. For details, see Querying a Protection Event.
You have added the website you want to protect to WAF or created a protection policy. For details, see Adding a Protection Policy.
Configuring an Information Leakage Prevention Rule
  1. Log in to the WAF console.
  2. Click in the upper left corner and select a region or project.
  3. (Optional) If you have enabled the enterprise project function, in the upper part of the navigation pane on the left, select your enterprise project from the Filter by enterprise project drop-down list. Then, WAF will display the related security data in the enterprise project on the page.
  4. In the navigation pane on the left, choose Policies > WAF Core Protection.
  5. In the policy list, click the name of the target policy to go to the protection rule configuration page.
    You can also go to the Assets > Protected Objects page, locate the target domain name, and click the number next to the protection policy in the Policy column to go to the protection rule configuration page.
  6. Locate the Information Leakage Prevention configuration area and toggle on this protection.
    : enabled.
  7. In the upper left corner above the Information Leakage Prevention rule list, click Add Rule.
  8. In the dialog box displayed, add an information leakage prevention rule by referring to Table 1. Figure 1 and Figure 2 are two examples.
    Information leakage prevention rules prevent sensitive information (such as ID numbers, phone numbers, and email addresses) from being disclosed. This type of rule can also block specified HTTP status codes.
    • Sensitive information filtering: Configure rules to mask sensitive information, such as phone numbers and ID numbers, from web pages. For example, you can set the following protection rules to mask sensitive information, such as ID numbers, phone numbers, and email addresses:
      Figure 1 Sensitive information leakage
    • Response code interception: An error page of a specific HTTP response code may contain sensitive information. You can configure rules to block such error pages to prevent such information from being leaked out. For example, you can set the following rule to block error pages of specified HTTP response codes 404, 502, and 503.
      Figure 2 Response code interception
    Table 1 Parameter description
    Example Value
    Path
    Enter the path for the information leakage prevention rule.
    • Do not include the domain name in the path. For example, if the URL to be protected is http://www.example.com/admin, set Path to /admin.
    • The path supports prefix match and exact match.
      • Prefix match: Only the prefix of the path to be entered must match that of the path to be protected.
        If the path to be protected is /admin, set Path to /admin.
      • Exact match: The entered path must be the same as the path to be protected.
    • Regular expressions are not supported.
    • The path cannot contain two or more consecutive slashes. If you enter ///admin, WAF will convert /// to /.
    /admin*
    Type
    Select the information type to be protected. You can select Sensitive information filtering or Response code interception.
    • Sensitive information filtering: Sensitive information such as ID card numbers, phone numbers, and email addresses will be masked.
    • Response code interception: Response pages with specified HTTP status codes will be blocked. Response codes 400, 401, 402, 403, 404, 405, 500, 501, 502, 503, 504, and 507 are supported.
    Content
    Protection content. Multiple options can be selected.
    • If you select Sensitive information filtering for Type, you can select Identification card, Phone number, and Email address for this parameter.
    • If you select Response code interception for Type, you can select 400, 401, 402, 403, 404, 405, 500, 501, 502, 503, 504, and 507 for this parameter.
    Identification card
    Protective Action
    Protective action for the rule when a request matches the rule. If you select Sensitive information filtering for Type, you can select Filter or Log only for Protective Action. If you select Response code interception for Type, you can select Block or Log only for Protective Action.
    • Block: WAF blocks requests with responses matching the selected response code.
      Besides that, WAF does not check these requests based on any other protection rules. Figure 1 shows the protection rule detection sequence.
    • Filter: Sensitive information will be masked with asterisks (*), or pages with specified HTTP status codes will be blocked.
    • Log only: Requests that hit the rule will be logged but not be blocked.
    Filter
    Rule Description
    Description of the rule.
    None
  9. Click OK. The added information leakage prevention rule is displayed in the list of information leakage prevention rules.
    To make the protection rule take effect, ensure that the protection policy to which the protection rule belongs has been applied to the target domain name. For details, see Adding a Domain Name to a Policy. A protection policy can be applied to multiple protected domain names, but a protected domain name can be added to only one protection policy.
    After completing the preceding configurations, you can:
    • Check the rule status: In the protection rule list, check the rule you added. Rule Status is Enabled by default.
    • Disable the rule: If you do not want the rule to take effect, click Disable in the Operation column of the rule.
    • Delete or modify the rule: Click Delete or Modify in the Operation column of the rule.
    • Verify the protection effect:
      1. Clear the browser cache and access the http://www.example.com/admin page. If the sensitive information on the page is masked, the rule takes effect.
      2. On the Events page, check the protection logs.
Configuration Example: Masking Sensitive Information
You can take the following steps to verify that WAF is protecting your website domain name (www.example.com) based on the information leakage prevention rule you configure.
  1. Locate the Information Leakage Prevention configuration area and toggle on this protection.
    : enabled.
  2. Add an information leakage prevention rule.
    Figure 3 Sensitive information leakage
  3. Clear the browser cache and access http://www.example.com/admin/.
    The email address, phone number, and identity number on the returned page are masked.
    Figure 4 Sensitive information masked
