Updated on 2025-10-27 GMT+08:00
Configuring Custom Precise Protection Rules
Precise protection does not take effect by default. You can combine conditions based on common HTTP fields (such as IP address, path, referer, user agent, and params) to screen out specified access requests, for example, specific attack requests, specific URL requests, and specified file types. This type of rule can be used in scenarios such as hotlinking prevention and website management background protection.
  • Only professional and enterprise editions for the cloud mode support reference table management. This function is not supported by standard edition for cloud mode.
  • Full Detection is not included in the WAF standard edition or cloud WAF billed on a pay-per-use basis.
  • The reference table function is not included in the WAF standard edition or cloud WAF billed on a pay-per-use basis.
  • The service edition and access mode you use determine whether you can configure a response field in the condition list. Response fields include Response Code, Response Length, Response Time, Response Header, and Response Body. The details are as follows:
    • Cloud mode - Load balancer access: not supported
    • Cloud mode - CNAME access: supported by the enterprise edition. To use it with other editions, submit a service ticket. For details, see Submitting a Service Ticket.
    • Dedicated mode access: supported
  • If Field in the Condition List is set to Method, Content cannot be set to TRACE or CONNECT. Otherwise, a parsing error will occur.
  • If you configure Protective Action to Block for a precise protection rule, you can configure a known attack source rule by referring to Configuring a Known Attack Source Rule to Block Specific Visitors for a Specified Duration. WAF will block requests matching the configured IP address, Cookie, or Params for a length of time configured as part of the rule.
  • The path content cannot contain the following special characters: (<>*)
  • It takes several minutes for a new rule to take effect. After the rule takes effect, protection events triggered by the rule will be displayed on the Events page.
  • With dedicated mode, if a layer-7 reverse proxy (for example, ELB load balancer) is deployed in front of WAF and the reverse proxy's fingerprints are transferred to WAF with request headers, you need to configure JA3/JA4 fingerprint tags for the protected domain name, or the rule with Condition set to TLS fingerprint (JA3) or TLS fingerprint (JA4) cannot work.
Configuring a Precise Protection Rule
  1. Log in to the WAF console.
  2. Click in the upper left corner and select a region or project.
  3. (Optional) If you have enabled the enterprise project function, in the upper part of the navigation pane on the left, select your enterprise project from the Filter by enterprise project drop-down list. Then, WAF will display the related security data in the enterprise project on the page.
  4. In the navigation pane on the left, click Policies.
  5. Click the name of the target policy to go to the protection rule configuration page.
    Before configuring protection rules, ensure that the target protection policy has been applied to a domain name. A protection policy can be applied to multiple protected domain names, but a protected domain name can have only one protection policy.
  6. Click the Precise Protection configuration area and ensure that Precise Protection is enabled.
    : enabled.
  7. On the Precise Protection page, set Detection Mode.
    Two detection modes are available:
    • Instant detection: If a request matches a configured precise protection rule, WAF immediately ends threat detection and blocks the request.
    • Full detection: If a request matches a configured precise protection rule, WAF finishes its scan first and then blocks all requests that match the configured precise protection rule.
  8. In the upper left corner above the Precise Protection rule list, click Add Rule.
  9. In the displayed dialog box, add a precise protection rule.
    The settings shown in Figure 1 are used as an example. If a visitor tries to access a URL containing /admin, WAF will block the request.
    To ensure that WAF blocks only attack requests, configure Protective Action to Log only first and check whether normal requests are blocked on the Events page. If no normal requests are blocked, configure Protective Action to Block.
    Figure 1 Add Precise Protection Rule
    Table 1 Rule parameters
    Example Value
    Rule Name
    Name of the rule.
    waftest
    Rule Description (Optional)
    Description of the rule.
    Condition List
    Request features to be matched by the rule. If a request matches the features, WAF handles the request according to the configured rule.
    • At least one condition is required for the rule to take effect. If multiple conditions are configured, the rule takes effect only when all conditions are met.
    • Click Add Condition to add a condition. You can add up to 30 conditions.
    • You can add a rate limit condition group.
      This function is under open beta test (OBT). You can submit a service ticket to enable it.
      • How a condition group takes effect: A condition group takes effect as long as one of the conditions in the group is met. Click Add Condition and add a rate limit condition in the group.
      • How condition groups take effect:
        • AND: The combination of an AND group takes effect when all AND groups are met. You can click Add AND Group to add an AND group.
        • OR: The combination of an OR group takes effect as long as one group is met. You can click Add OR Group to add an OR group.
    • Path Include /admin
    • User Agent Prefix is not mozilla/5.0
    • IP Equal to 192.168.2.3
    • Cookie key1 Prefix is not jsessionid
    Deep Inspection
    Assume that you set Field in the condition list to one of the following:
    • Path: Content supports Case-Sensitive.
    • User Agent: Content supports Case-Sensitive.
    • Params: Content supports Case-Sensitive.
    • Cookie: Content supports Case-Sensitive.
    • Header: Subfield supports Case-Sensitive, and Content also supports Case-Sensitive.
    If you enable Deep Inspection, the Subfield and Content will be decoded and matched conditions in a case-insensitive manner. Deep Inspection supports Base64 decoding.
    Protective Action
    Protective action for the rule when a request matches the rule.
    • Block: Requests that match the rule will be blocked.
      Block Page for the Block action. The default value of Block Page is Default. You can customize the block page.
      • Block Page
        This parameter is mandatory when Protective Action is set to Block. If a request meets the rule, the configured block page is returned.
        • Default settings (default): The default block page is returned.
        • Custom: You can customize the return code, response header, page type, and page content for the returned page. For more information, see Modifying the Alarm Page.
        • Redirection: Requests to the protected website are redirected to a specified URL.
          The root domain name of the redirection URL must be the same as the currently protected domain name (including a wildcard domain name). For example, if the protected domain name is www.example.com and the port is 8080, the redirection URL can be set to http://www.example.com:8080/error.html.
      • Known Attack Source
        You can configure a long-term or short-term block rule based on the IP address, cookie, or parameter of a visitor. WAF will then automatically block the visitor if the request hits the rule. For more details, see Configuring a Known Attack Source Rule to Block Specific Visitors for a Specified Duration.
    • Allow: Requests that hit the rule are forwarded to backend servers.
    • Log only: Requests that hit the rule are not blocked but logged.
    • JS Challenge: WAF returns a piece of JavaScript code that can be automatically executed by a normal browser to the client. If the client properly executes the JavaScript code, WAF allows all requests from the client within the validity period of the token. During this period, no verification is required. If the client fails to execute the code, WAF blocks the requests.
      The default validity period of a token is 30 minutes. You can customize the validity period from 60 to 86,400 seconds.
      CAUTION:
      • If the initial page automatically loads an Ajax request, you need to configure a precise protection rule and configure the JS challenge action for pages containing Ajax requests, such as the referer page or homepage for the Ajax interface. This step prevents asynchronous interface requests, automatically triggered by JavaScript on the origin server, from executing before the WAF SDK. If the static page does not automatically trigger asynchronous interfaces, this issue does not apply.
      • If the referer in the request is different from the current host, the JS challenge does not work.
    Block
    Application Schedule
    Time when the rule takes effect.
    • Immediate: The rule works immediately after it is enabled.
    • Custom: You can select a time range for the rule to work.
    Immediate
    Priority
    Rule priority. If you have added multiple rules, rules are matched by priority. The smaller the value you set, the higher the priority.
    You can use the priority function to rank all precise protection rules to get the optimal protection.
    If multiple precise access control rules have the same priority, WAF matches the rules in the sequence of time the rules are added.
    5
  10. Click OK. You can then view the added precise protection rule in the protection rule list.
    After completing the preceding configurations, you can:
    • Check the rule status: In the protection rule list, check the rule you added. Rule Status is Enabled by default.
    • Disable the rule: If you do not want the rule to take effect, click Disable in the Operation column of the rule.
    • Delete the rule: To delete a rule you no longer need, click Delete in the Operation column of the rule.
    • Modify or copy the rule: Click More > Modify or More > Copy in the Operation column of the target rule, respectively.
    • Verify the protection effect:
      1. Clear the browser cache and enter http://www.example.com/admin (or any page containing /admin) in the address bar. Normally, WAF blocks the requests that meet the conditions and returns the block page.
      2. On the Events page, check the protection logs.
Configuration Example: Blocking a Certain Type of Attack Requests
Analysis of a specific type of WordPress pingback attack shows that the User Agent field contains WordPress.
Figure 2 WordPress pingback attack
A precise rule as shown in the figure can block this type of attack.
Figure 3 User Agent configuration
Configuration Example: Blocking Requests to a Certain URL
If a large number of IP addresses are accessing a URL that does not exist, configure the following protection rule to block such requests to reduce resource usage on the origin server. Figure 4 shows an example.
Figure 4 Blocking requests to a specific URL
Blocking Requests with null Fields
You can configure precise protection rules to block requests having null fields. Figure 5 shows an example.
Figure 5 Blocking requests with empty Referer
Blocking Specified File Types (ZIP, TAR, and DOCX)
You can configure file types that match the path field to block specific files of certain types. For example, if you want to block .zip files, you can configure a precise protection rule as shown in Figure 6 to block access requests of .zip files.
Figure 6 Blocking requests of specific file types
Configuration Example: Preventing Hotlinking
You can configure a protection rule based on the Referer field to enable WAF to block hotlinking from a specific website. If you find out that, for example, requests from https://abc.blog.com are stealing images from your site, you can configure a rule to block such requests.
Figure 7 Preventing hotlinking
Configuration Example: Allowing All Requests from Whitelisted IP Addresses
You can configure two precise protection rules, one to block all IP addresses, as shown in Figure 8, but then another one to allow a specific IP address, as shown in Figure 9.
Figure 8 Blocking all requests
Figure 9 Allowing the access of a specified IP address
Configuration Example: Allowing All Requests from Whitelisted IP Addresses That Carry a Specified URL Feature
You can configure multiple conditions in Condition List to allow a whitelisted IP address based on the request URL feature (for example, the path contains /admin).
Figure 10 Blocking access from non-whitelisted IP addresses to a specific path
