Help Center/ VPC Endpoint/ User Guide/ VPC Endpoint Services/ Creating a VPC Endpoint Service
Updated on 2025-11-12 GMT+08:00
There are two types of VPC endpoint services: gateway and interface.
  • Gateway VPC endpoint services are created only for cloud services.
  • Interface VPC endpoint services can be created for both cloud services and your private services. Cloud services are configured as VPC endpoint services by the O&M personnel by default. However, you need to create VPC endpoint services for your private services.
This section describes how to configure a private service into an interface VPC endpoint service.
  • VPC endpoint services are region-level resources. Select a region and project when you create such a service.
  • Each tenant can create a maximum of 20 VPC endpoint services.
  • The following private services can be configured into VPC endpoint services:
    • Elastic load balancer: Backend resources of this type suit services that receive high access traffic and demand high reliability and disaster recovery (DR) performance.
    • ECS: Backend resources of this type serve as servers.
    • BMS: Backend resources of this type serve as servers.
  • One VPC endpoint service corresponds to only one backend resource.
  • If a Layer 7 load balancer is configured as a backend resource, Proxy Protocol must be disabled.
There is a load balancer in the VPC where you want to create a VPC endpoint service.
  1. Go to the VPC endpoint service list page.
  2. Click Create VPC Endpoint Service.
    The Create VPC Endpoint Service page is displayed.
    Figure 1 Create VPC Endpoint Service
  3. Configure parameters by referring to Table 1.
    Table 1 Parameters for creating a VPC endpoint service
    Region
    Specifies the region where the VPC endpoint service is to be deployed.
    Resources in different regions cannot communicate with each other over an intranet. For lower latency and quicker access, select the nearest region.
    Name
    This parameter is optional.
    Specifies the name of the VPC endpoint service.
    The name can contain a maximum of 16 characters, including letters, digits, underscores (_), and hyphens (-).
    • If you do not enter a name, the system generates a name in {region}.{service_id} format.
    • If you enter a name, the system generates a name in {region}.{Name}.{service_id} format.
    Network Type
    Specifies the type of the VPC endpoint service.
    The value can be IPv4 or IPv6.
    • IPv4: Only IPv4 networks are supported.
    • IPv6: Only IPv6 networks are supported.
    VPC
    Specifies the VPC where the VPC endpoint service is to be deployed.
    Subnet
    Specifies the subnet where the VPC endpoint service is to be deployed.
    This parameter is mandatory when you select IPv6 for Network Type.
    Service Type
    Specifies the type of the VPC endpoint service. The type can only be Interface.
    Connection Approval
    Specifies whether the connection between a VPC endpoint and a VPC endpoint service requires approval from the owner of the VPC endpoint service.
    You can enable or disable Connection Approval.
    When Connection Approval is enabled, any VPC endpoint for connecting to the VPC endpoint service needs to be approved. For details, see Managing Connections of a VPC Endpoint Service.
    Port Mapping
    Specifies the protocol and ports used for communications between the VPC endpoint service and a VPC endpoint. The protocol is TCP or UDP.
    • Service Port: a backend resource port to provide a service.
    • Endpoint Port: a VPC endpoint port for you to access a VPC endpoint service.
    The service and endpoint port numbers range from 1 to 65535. A maximum of 50 port mappings can be added at a time.
    Accessing a VPC endpoint service from a VPC endpoint is to access the service port from the associated endpoint port.
    Backend Resource Type
    Specifies the backend resource that provides services to be accessed.
    The following backend resource types are supported:
    In this example, select Elastic load balancer.
    • For the security group associated with the backend resource configured for the VPC endpoint service, add an inbound rule, with Source set to 198.19.128.0/17. For details, see Adding a Security Group Rule in the Virtual Private Cloud User Guide.
    • If you configure a load balancer as the backend resource for the VPC endpoint service, and enable access control for the listener associated with the load balancer, ensure to allow traffic from 198.19.128.0/17.
    Load Balancer
    When Backend Resource Type is set to Elastic load balancer, select the load balancer that provides services from the drop-down list.
    If an elastic load balancer is used as the backend resource, the source IP address received by the VPC endpoint service is not the real address of the client.
    ECS List
    This parameter is available when you select ECS for Backend Resource Type. Select an ECS from the ECS list.
    BMS List
    This parameter is available when you select BMS for Backend Resource Type. Select a BMS from the BMS list.
    The BMS type will be discarded. The ELB type is recommended.
    Enterprise Project
    Centrally manages cloud resources and members by project.
    Tag (Optional)
    Specifies the VPC endpoint service tag, which consists of a key and a value. You can add up to 20 tags to each VPC endpoint service.
    Tag keys and values must meet requirements listed in Table 2.
    If a predefined tag has been created on TMS, you can directly select the corresponding tag key and value.
    For details about predefined tags, see Predefined Tag Overview.
    If you have configured tag policies for VPC Endpoint, add tags to VPC endpoint services based on the tag policies. If you add a tag that does not comply with the tag policies, VPC endpoint services may fail to be created. Contact your administrator to learn more about tag policies.
    Description (Optional)
    Provides supplementary information about the VPC endpoint service.
    Table 2 Tag requirements for VPC endpoint services
    Requirement
    Tag key
    • Cannot be left blank.
    • Must be unique for each resource.
    • Can contain a maximum of 128 characters.
    • A tag key can contain letters, digits, spaces, and any of the following characters: _.:=+-@. It cannot start or end with a space, or start with _sys_.
    Tag value
    • Can be left blank.
    • Can contain a maximum of 255 characters.
    • A tag value can contain letters, digits, spaces, and characters _.:/=+-@. It cannot start or end with a space.
  4. Click Create Now.
  5. Click Back to VPC Endpoint Service List to view the newly-created VPC endpoint service.
