Managing Subnet CIDR Reservations
Precautions
- Start IP address: 192.168.1.0
- End broadcast address: 192.168.1.255
- Assigned IP addresses
- Subnet gateway address: 192.168.1.1
- DHCP address: 192.168.1.254
- System interface address: 192.168.1.253
- IP addresses used by instances in the subnet
You can view the IP addresses that are already in use in a subnet by referring to Viewing IP Addresses in a Subnet.
Creating a Subnet CIDR Reservation
- Go to the subnet list page.
- Locate the target subnet and click its name.
- Click the CIDR Reservations tab. In the upper left corner of the CIDR reservation list, click Add CIDR Reservation.
- Configure the CIDR reservation parameters as needed.
For details, see Table 1.
Table 1 Parameters for configuring a CIDR reservation Parameter
Example Value
Name
Mandatory
Enter a name for the CIDR reservation. The name:
- Can contain 1 to 64 characters.
- Can contain letters, digits, underscores (_), hyphens (-), and periods (.).
CIDR reservations can share the same name, but each one has a unique ID assigned by the system.
subnet-reserved-cidr-01
IP Address Version
Mandatory
Set the IP address version supported by the CIDR reservation. There are two options:- IPv4
- IPv6: If you select this option, the subnet must have IPv6 enabled.
To enable IPv6:
- In the subnet list, locate the target subnet and click Enable IPv6 in the IPv6 CIDR Block column.
- In the Summary tab of the target subnet, click Enable for IPv6 CIDR Block.
IPv4
Creation Method
Mandatory
Define how you want to add a CIDR reservation. There are two options:
- Specify CIDR block: You need to enter a CIDR block.
A CIDR reservation must be a subset of its subnet CIDR block and cannot contain the start IP address, end IP address, and assigned IP addresses in the subnet CIDR block. The following are examples:
- IPv4 CIDR block: If the subnet CIDR block is 192.168.1.0/24, you can set the CIDR reservation to 192.168.1.128/26.
- IPv6 CIDR block: If the subnet CIDR block is 2407:c080:1200:2515::/64, you can set the CIDR reservation to 2407:c080:1200:2515:6a8c::/80.
- Specify mask length: You need to enter a mask length. The length must be an integer.
The minimum mask length is the subnet mask length plus 2. The system will assign a CIDR reservation based on the mask length you have specified. The following are examples:
- IPv4 CIDR block mask length: If the subnet CIDR block is 192.168.1.0/24 and the subnet mask is 24, the CIDR reservation mask ranges from 26 to 32. If you set the mask length to 26, the system automatically assigns a CIDR reservation of 192.168.1.128/26.
- IPv6 CIDR block mask length: If the subnet CIDR block is 2407:c080:1200:2515::/64 and the subnet mask is 64, the CIDR reservation mask ranges from 66 to 128. If you set the mask length to 80, the system automatically assigns a CIDR reservation of 2407:c080:1200:2515:7a3d::/80.
- Specify CIDR block: 192.168.1.128/26
- Specify mask length: 26
Optional
Enter a description about the CIDR reservation in the text box as required.
The description can contain a maximum of 255 characters and cannot contain angle brackets (< or >).
- Click OK.
Return to the CIDR reservation list and view the CIDR reservations in the current subnet.
Modifying the Name and Description of a CIDR Reservation
- Click the CIDR Reservations tab. In the CIDR reservation list, locate the target CIDR reservation and click
on the right of its name or description and enter a different value.
Table 2 Parameter descriptions Parameter
Example Value
Name
Name of the CIDR reservation. The name:
subnet-reserved-cidr-02
Description of the CIDR reservation.
- Click OK.
Deleting a Subnet CIDR Reservation
- Click the CIDR Reservations tab. In the CIDR reservation list, locate the target CIDR reservation and click Delete in the Operation column.
A confirmation dialog box is displayed.
- Confirm the information and click OK.
After a CIDR reservation is deleted, the IP addresses in the CIDR block will be assigned to instances in the subnet.
