Updated on 2025-08-27 GMT+08:00
Obtaining a VPC ID
This section describes how to view and obtain a VPC ID.
If you create a VPC peering connection between two VPCs in different accounts, you need to obtain the project ID of the region that the peer VPC resides. You can recommend this section to the user of the peer VPC to obtain the project ID.
  1. Go to the VPC list page.
  2. On the Virtual Private Cloud page, locate the VPC and click its name.
    The VPC details page is displayed.
  3. In the VPC Information area, view the VPC ID.
    Click next to ID to copy the VPC ID.
    Figure 1 VPC ID
