Help Center/ Virtual Private Cloud/ User Guide/ Virtual IP Address/ Unbinding a Virtual IP Address from an Instance or EIP
Updated on 2026-03-23 GMT+08:00
You can unbind a virtual IP address from an instance or EIP. An instance can be a cloud server, network interface, or Layer 2 connection. For detailed operations, see:
- Go to the subnet list page.
- In the subnet list, locate the target subnet and click its name.
- Click the IP Addresses tab.
The virtual IP address list is displayed.
- Locate the row that contains the virtual IP address, click More in the Operation column, and select Unbind from Instance.
A confirmation dialog box is displayed.
- In the displayed dialog box, perform the following operations to unbind the virtual IP address from the instance:
- Select the type of the instance bound to the virtual IP address.
- Locate the row that contains the instance and click Unbind in the Operation column.
- Confirm the information and click OK.
Unbinding a Virtual IP Address from an EIP
- Click
in the upper left corner and choose Networking > Virtual Private Cloud. The Virtual Private Cloud page is displayed.
- Locate the target virtual IP address, click More in the Operation column, and select Unbind from EIP.
