Virtual IP Address Overview
What Is a Virtual IP Address?
- Bind one or more virtual IP addresses to a cloud server so that you can use either the virtual or private IP address to access the server. If you have multiple services running on a cloud server, you can use different virtual IP addresses to access them.
- Bind a virtual IP address to multiple cloud servers. You can use a virtual IP address and an HA software (such as Keepalived) to set up a high-availability active/standby cluster. If you want to improve service availability and avoid single points of failure, you can deploy cloud servers in the active/standby mode or deploy one active cloud server and multiple standby cloud servers. In this arrangement, the cloud servers all use the same virtual IP address. If the active cloud server goes down, the standby cloud server becomes the active server and continues to provide services.
- Private IP addresses are used for internal network communication.
- The virtual IP address works with Keepalived to build an HA cluster. ECSs in this cluster can be accessed through one virtual IP address.
- EIPs are used for Internet communication.
Application Scenarios
You can use a virtual IP address and Keepalived to set up a high-availability active/standby cluster. If the active cloud server goes down, the standby server becomes the active server and continues to provide services. The following describes the typical application scenarios of virtual IP addresses.
Figure 2 shows a high-availability cluster that is set up using a virtual IP address and Keepalived. They work as follows:
- Virtual IP address 192.168.0.177 is bound to ECS-HA1 and ECS-HA2. Keepalived is configured on the two ECSs.
- EIP-A is bound to the virtual IP address so that the ECSs can be accessed from the Internet.
In this cluster, ECS-HA1 works as the active ECS and provides services accessible from the Internet using EIP-A. ECS-HA2 works as the standby ECS, with no services deployed on it. If ECS-HA1 goes down, ECS-HA2 takes over services, ensuring service continuity.
For details about how to set up an HA cluster, see Using a Virtual IP Address and Keepalived to Set Up a High-Availability Web Cluster.
- Virtual IP address 10.10.1.10 is bound to ECS-01 and ECS-02. Keepalived and LVS (DR mode) are configured on ECS-01 and ECS-02 to set up the active/standby LVS servers. In this way, requests from clients can be evenly distributed to different backend servers.
- ECS-03 and ECS-04 are configured as backend servers to handle service requests.
- The source/destination check option needs to be disabled.
When you bind a virtual IP address to an ECS, the source/destination check option of the ECS's network interface is automatically disabled. If the option is not disabled, disable it.
In this load balancing cluster, ECS-01 works as the active LVS server to distribute requests from clients. If ECS-01 is faulty, ECS-02 takes over and distributes requests from clients, ensuring high availability of the LVS cluster.
For details about how to install and configure Keepalived and LVS services and how to configure backend servers, see the common practices in the industry.
Virtual IP Address Quotas
| Item | Default Quota | Adjustable |
| Maximum number of virtual IP addresses per region | 2 | Yes. For details, see Managing Quotas. |
| Maximum number of EIPs that a virtual IP address can be bound to | 1 | No |
| Maximum number of instances (including cloud servers and network interfaces) that a virtual IP address can be bound to | 10 | No |
Notes and Constraints
- If a cloud server has multiple network interfaces that are in the same subnet, you are not advised to bind virtual IP addresses to the network interfaces. There may be route conflicts on the ECS, which would cause communication failure using the virtual IP address.
- A virtual IP address is assigned from a VPC subnet. They can only be bound to a cloud server in the same subnet as the virtual IP address.
- Virtual IP addresses and extended network interfaces cannot be used to directly access Huawei Cloud services, such as DNS. You can use VPC endpoints to access these services. For details, see Buying a VPC Endpoint.
- If you use virtual IP addresses and Keepalived to set up a HA cluster with cloud servers working in the active/standby pair, backend cloud servers bound with the same virtual IP address will receive same data packets.
- Cross-VPC communication: After two VPCs are connected through a VPC peering, Direct Connect, VPN, or Cloud Connect connection, if the active/standby cloud servers in the HA cluster are bound with the same virtual IP address in a VPC, both the cloud servers working in the active/standby pair will receive the request data packets from the other VPC. For example, suppose VPC-A and VPC-B are connected through a VPC peering connection, and ECS-A01 and ECS-A02 in VPC-A work in an active/standby pair and are bound with the same virtual IP address. If ECS-B in VPC-B sends a request to the HA cluster, both ECS-A01 and ECS-A02 will receive the request packet.
- Public network access: If the active/standby servers in the HA cluster are bound with the same virtual IP address that has an EIP bound, both cloud servers working in the active/standby pair will receive request packets when the requests are initiated from the Internet. For example, if ECS-C01 and ECS-C02 in VPC-C are bound with the same virtual IP address, and this virtual IP address is bound with an EIP, both ECSs working in an active/standby pair can provide services accessible from the Internet. If an access request is initiated from the public network, both ECS-C01 and ECS-C02 will receive request packets.
