Deleting a Supplementary Network Interface
If you want to delete a supplementary network interface with an EIP bound, you have to first unbind the EIP from the interface.
Notes and Constraints
- Deleting a supplementary network interface will also detach it from its network interface.
- Deleting a supplementary network interface will also unbind its EIP. You can choose to release the EIP if needed.
If you do not release the EIP, the EIP will continue to be billed, but you can still bind it to other cloud resources.
- If a supplementary network interface has resources associated, deleting the interface will also delete any rules for associated resources that reference it.
For example, deleting a supplementary network interface that is used as the next hop for a custom route in a VPC route table will also delete the associated route.
- Go to the supplementary network interface list page.
- Locate the row that contains the supplementary network interface and click Delete in the Operation column.
A confirmation dialog box is displayed.
- Confirm the information and click OK.
Deleting a supplementary network interface will also delete the VLAN sub-interfaces configured on the ECS.
