Modifying a Route
You can modify an existing route in a route table.
If a route table is associated with a subnet, modifying rules in the route table may affect how and where traffic is directed. Be careful with this operation as it may interrupt services.
Notes and Constraints
- System routes cannot be modified.
- When you create a VPN, Cloud Connect, or Direct Connect connection, the default route table automatically delivers a route that cannot be deleted or modified.
- Routes with the next hop type of cloud container cannot be modified or deleted.
- Routes with the next hop type of VPC endpoint cannot be modified or deleted.
- Go to the route table list page.
- Locate the target route table and click its name.
- Locate the target route and click Modify in the Operation column.
- Modify the route information in the displayed dialog box.
Table 1 Parameter descriptions Parameter
Example Value
Destination Type
Mandatory
The destination type can only be IP address. You can set an IP address or CIDR block.
IP address
Destination
Mandatory
Enter the destination of the route. You can enter a single IP address or an IP address range in CIDR notation.
The destination of the default route is 0.0.0.0/0, indicating that any traffic is matched.
NOTE:If an IP address group contains an IP address range in the format of Start IP address-End IP address, the IP address group is not supported.
For example, an IP address group cannot contain 192.168.0.1-192.168.0.62. You need to change 192.168.0.1-192.168.0.62 to 192.168.0.0/26.
IPv4: 192.168.0.0/16
Next Hop Type
Mandatory
Set the type of the next hop.
NOTE:When you add or modify a custom route in a default route table, the next hop type of the route cannot be set to VPN gateway, Direct Connect gateway, or Cloud connection.
VPC peering connection
Next Hop
Mandatory
Set the next hop. The resources in the drop-down list box are displayed based on the selected next hop type.
peer-AB
Optional
Enter the description of the route in the text box as required.
- Click OK.
