Help Center/ Virtual Private Cloud/ User Guide/ Route Table and Route/ Managing Route Tables/ Changing the Route Table Associated with a Subnet
Updated on 2025-08-01 GMT+08:00
You can change the route table for a subnet. If the route table is changed, routes in the new route table will apply to all cloud resources in the subnet.
  1. Go to the route table list page.
  2. Click the name of the target route table.
  3. On the Associated Subnets tab page, click Change Route Table in the Operation column and select a new route table as prompted.
  4. Click OK.
    After the route table is changed, routes in the new route table will apply to all cloud resources in the subnet.
