Updated on 2024-10-15 GMT+08:00
Route Tables and Routes
What Is a Route Table?
A route table contains a set of routes that are used to control the traffic in and out of your subnets in a VPC. Each subnet must be associated with a route table. A subnet can only be associated with one route table, but you can associate multiple subnets with the same route table.
Both IPv4 and IPv6 routes are supported.
Figure 1 Route tables
  • Default route table: Each VPC comes with a default route table. If you create a subnet in the VPC, the subnet associates with the default route table. The default route table ensures that subnets in a VPC can communicate with each other.
    • You can add routes to, delete routes from, and modify routes in the default route table, but cannot delete the table.
    • When you create a VPN, Cloud Connect, or Direct Connect connection, the default route table automatically delivers a route that cannot be deleted or modified.
  • Custom route table: If you do not want to use the default route table, you can create a custom route table and associate it with the subnet. Custom route tables can be deleted if they are no longer required.
    The custom route table associated with a subnet affects only the outbound traffic. The default route table of a subnet controls the inbound traffic.
By default, the quota for custom route tables is 0. To create custom route tables, apply for a quota increase first.
Route
You can add routes to both default and custom route tables and configure the destination, next hop type, and next hop for the routes to determine where network traffic is directed. Routes are classified into system routes and custom routes.
  • System route: A system route is automatically added by the VPC service or other services (such as VPN and Direct Connect) and cannot be deleted or modified.
    Each route table comes with routes whose next hops are Local. Generally, a route table contains the following local routes:
    • Routes whose destination is 100.64.0.0/10 (IP address range used to deploy public services, for example, the DNS server). The routes direct instances in a subnet to access these services.
    • Routes whose destination is 198.19.128.0/20 (IP address range used by internal services, such as VPC Endpoint).
    • Routes whose destination is 127.0.0.0/8 (local loopback addresses)
    • Routes whose destination is a subnet CIDR block and that enable instances in a VPC to communicate with each other.
      If you enable IPv6 when creating a subnet, the system automatically assigns an IPv6 CIDR block to the subnet. Then, you can view IPv6 routes in its route table. Example destinations of subnet CIDR blocks are as follows:
      • IPv4: 192.168.2.0/24
      • IPv6: 2407:c080:802:be7::/64
  • Custom route: After a route table is created, you can add custom routes and configure information such as the destination and next hop in the route to determine where network traffic is directed. In addition to manually added custom routes, there are custom routes added by other cloud services, such as Cloud Container Engine (CCE) or NAT Gateway.
    Route tables include default route tables and custom route tables. They support the next hop types described in Table 1 and Table 2.
    Table 1 Next hop types supported by the default route table
    Next Hop Type
    Server
    Traffic intended for the destination is forwarded to an ECS in the VPC.
    Extension NIC
    Traffic intended for the destination is forwarded to the extension NIC of an ECS in the VPC.
    Supplementary network interface
    Traffic intended for the destination is forwarded to the supplementary network interface of an ECS in the VPC.
    NAT gateway
    Traffic intended for the destination is forwarded to a NAT gateway.
    VPC peering connection
    Traffic intended for the destination is forwarded to a VPC peering connection.
    Virtual IP address
    Traffic intended for the destination is forwarded to a virtual IP address and then sent to active and standby ECSs to which the virtual IP address is bound.
    VPC endpoint
    Traffic intended for the destination is forwarded to a VPC endpoint.
    Cloud container
    Traffic intended for the destination is forwarded to a cloud container.
    Enterprise router
    Traffic intended for the destination is forwarded to an enterprise router.
    Cloud firewall
    Traffic intended for the destination is forwarded to a cloud firewall.
    Global internet gateway
    Traffic intended for the destination is forwarded to a global internet gateway.
    Table 2 Next hop types supported by a custom route table
    Next Hop Type
    Server
    Extension NIC
    BMS user-defined network
    Traffic intended for the destination is forwarded to a BMS user-defined network.
    VPN gateway
    Traffic intended for the destination is forwarded to a VPN gateway.
    Direct Connect gateway
    Traffic intended for the destination is forwarded to a Direct Connect gateway.
    Cloud connection
    Traffic intended for the destination is forwarded to a cloud connection.
    NAT gateway
    Virtual IP address
    VPC endpoint
    Cloud container
    Enterprise router
    Cloud firewall
    If you specify the destination when creating a resource, a system route is delivered. If you do not specify a destination when creating a resource, a custom route that can be modified or deleted is delivered.
    For example, when you create a NAT gateway, the system automatically delivers a custom route without a specific destination (0.0.0.0/0 is used by default). In this case, you can change the destination. However, when you create a VPN gateway, you need to specify the remote subnet as the destination of a route. In this case, this route will be delivered as a system route. Do not modify the route destination on the Route Tables page. If you do, the destination will be inconsistent with the configured remote subnet. To modify the route destination, go to the specific resource page and modify the remote subnet, then the route destination will be changed accordingly.
    You cannot add a route whose next hop type is VPC endpoint or Cloud container to a route table. These routes are automatically added by the VPC Endpoint or CCE service.
Notes and Constraints
When you create a VPC, the system automatically generates a default route table for the VPC. You can also create a custom route table.
  • A VPC can be associated with a maximum of five route tables, including the default route table and four custom route tables.
  • All route tables in a VPC can have a maximum of 1,000 routes, excluding system routes.
In each VPC route table, there are local routes and custom routes.
  • Generally, the destination of a custom route cannot overlap with that of a local route. The destination of a local route can be a subnet CIDR block and CIDR blocks that are used for internal communications.
  • You cannot add two routes with the same destination to a VPC route table even if their next hop types are different.
  • In a VPC route table, the route priority is as follows:
    • Local route: A route that is added by the system within a VPC. They have higher priorities than custom routes.
    • Custom route: A route that is defined yourself or that is added by the system when you create other instances.
      If there are multiple custom routes that match the request destination, the longest prefix match routing is used. This means the route that has the longest subnet mask is preferentially used to determine the next hop. For example, when 192.168.1.12/32 is being looked up, two routes are checked: the first route with destination of 192.168.0.0/16 and next hop of ECS ECS-A, and the second route with destination of 192.168.1.0/24 and next hop of peering connection Peering-AB. In this case, the second route is preferentially used to route the request, since its subnet mask (/24) is longer than the other route's mask (/16).
      If a custom route in the route table points to 0.0.0.0/0 and an ECS in the subnet has an EIP bound, the EIP has a higher priority. In this case, the EIP is used to access the Internet by default.
    Figure 2 Viewing VPC route tables
Custom Route Table Configuration Process
Figure 3 Process for configuring a route table
Table 3 Process for configuring a route table
No.
Step
Reference
Create a custom route table.
If your default route table cannot meet your service requirements, you can create a custom route table.
The custom route table associated with a subnet only controls the outbound traffic. The default route table of a subnet controls the inbound traffic.
Creating a Custom Route Table
2
Add a route.
You can add a custom route and configure information such as the destination and next hop in the route to determine where network traffic is directed.
Adding Routes to a Route Table
3
Associate the route table with a subnet.
After a route table is associated with a subnet, the routes in the route table control the routing for the subnet and apply to all cloud resources in the subnet.
Associating a Route Table with a Subnet
