Help Center/ Virtual Private Cloud/ User Guide/ VPC Peering Connection/ VPC Peering Connection Usage/ Using a VPC Peering Connection to Connect ECSs in Two VPCs
Updated on 2024-07-30 GMT+08:00
You can configure a VPC peering connection and set the destination of the routes added to VPC route tables to the private IP address of ECS in the peer VPC. In this way, the two ECS are connected.
To enable traffic forwarding among these ECSs, you need to add routes with private IP addresses of these ECSs as the destinations and a VPC peering connection as the next hop to VPC route tables. Table 1 shows example scenarios.
Table 1 Scenario description
Scenario Description
IP Address Version
Example
ECS in a central VPC peered to ECSs in two other VPCs
You want a central VPC to communicate with the other two VPCs. However, you do not want the other two VPCs to communicate with each other.
The other two VPCs have the same CIDR block and also include subnets that overlap. To prevent route conflicts in the central VPC, you can configure VPC peering connections to connect to specific ECSs in the other two VPCs.
IPv4
ECS in a Central VPC Peered to ECSs in Two Other VPCs (IPv4)
A central VPC peered with two other VPCs using longest prefix match
This scenario is similar to the preceding one. In addition to peering specific ECSs, you can create the following VPC peering connections based on the longest prefix match rule:
  • Create a VPC peering connection between the central VPC and an ECS in VPC-B
  • Create a VPC peering connection between the central VPC and a subnet in VPC-C
This configuration expands the communication scope.
IPv4
A Central VPC Peered with Two Other VPCs Using Longest Prefix Match (IPv4)
You want to create a VPC peering connection between VPC-A and VPC-B, and between VPC-A and VPC-C. VPC-B and VPC-C have matching CIDR blocks. You can set the destinations of routes to private IP addresses of specific ECSs to limit traffic to these ECSs. If the destination of a route is not properly planned, traffic cannot be correctly forwarded. For details, see One Central VPC Peered to Overlapping Subnets from Two VPCs (IPv4).
In this example, you need to create Peering-AB between ECS-A01-1 in VPC-A and ECS-B01 in VPC-B, and Peering-AC between ECS-A01-2 in VPC-A and ECS-C01 in VPC-C. Subnet-B01 and Subnet-C01 have matching CIDR blocks. The private IP addresses of ECS-B01 and ECS-C01 must be different. Otherwise, there will be route conflicts because the route table of VPC-A will have routes with the same destination.
  • For details about resource planning, see Table 2.
  • For details about VPC peering relationships, see Table 3.
Figure 1 Networking diagram (IPv4)
Table 2 Resource planning details (IPv4)
VPC Name
VPC CIDR Block
Subnet Name
Subnet CIDR Block
VPC Route Table
ECS Name
Security Group
Private IP Address
VPC-A
172.16.0.0/16
Subnet-A01
172.16.0.0/24
rtb-VPC-A
ECS-A01-1
sg-web: general-purpose web server
172.16.0.111
ECS-A01-2
172.16.0.218
VPC-B
10.0.0.0/16
Subnet-B01
10.0.0.0/24
rtb-VPC-B
ECS-B01
10.0.0.139
VPC-C
10.0.0.0/16
Subnet-C01
10.0.0.0/24
rtb-VPC-C
ECS-C01
10.0.0.71
Table 3 Peering relationships (IPv4)
Peering Relationship
Peering Connection Name
Local VPC
Peer VPC
ECS-A01-1 in VPC-A is peered with ECS-B01 in VPC-B.
Peering-AB
VPC-A
VPC-B
ECS-A01-2 in VPC-A is peered with ECS-C01 in VPC-C.
Peering-AC
VPC-A
VPC-C
After the VPC peering connections are created, add the following routes to the route tables of the local and peer VPCs:
Table 4 VPC route table details (IPv4)
Route Table
Destination
Next Hop
Route Type
rtb-VPC-A
172.16.0.0/24
Local
System
Local routes are automatically added for communications within a VPC.
10.0.0.139/32 (ECS-B01)
Peering-AB
Custom
Add a route with the private IP address of ECS-B01 as the destination and Peering-AB as the next hop.
10.0.0.71/32 (ECS-C01)
Peering-AC
Custom
Add a route with the private IP address of ECS-C01 as the destination and Peering-AC as the next hop.
rtb-VPC-B
10.0.0.0/24
Local
System
172.16.0.111/32 (ECS-A01-1)
Peering-AB
Custom
Add a route with the private IP address of ECS-A01-1 as the destination and Peering-AB as the next hop.
rtb-VPC-C
10.0.0.0/24
Local
System
172.16.0.218/32 (ECS-A01-2)
Peering-AC
Custom
Add a route with the private IP address of ECS-A01-2 as the destination and Peering-AC as the next hop.
In this example, you need to create Peering-AB between central VPC-A and ECS-B01 in VPC-B, and Peering-AC between central VPC-A and VPC-C. Subnet-B01 and Subnet-C01 have matching CIDR blocks. You can use the longest prefix match rule to control traffic forwarding.
  • For details about resource planning, see Table 5.
  • For details about VPC peering relationships, see Table 6.
Figure 2 Networking diagram (IPv4)
Table 5 Resource planning details (IPv4)
VPC Name
VPC CIDR Block
Subnet Name
Subnet CIDR Block
VPC Route Table
ECS Name
Security Group
Private IP Address
VPC-A
172.16.0.0/16
Subnet-A01
172.16.0.0/24
rtb-VPC-A
ECS-A01
172.16.0.111
Subnet-A02
172.16.1.0/24
rtb-VPC-A
ECS-A02
172.16.1.91
VPC-B
10.0.0.0/16
Subnet-B01
10.0.0.0/24
rtb-VPC-B
ECS-B01
10.0.0.139
VPC-C
10.0.0.0/16
Subnet-C01
10.0.0.0/24
rtb-VPC-C
ECS-C01
10.0.0.71
Table 6 Peering relationships (IPv4)
Local VPC
Peer VPC
Peering-AB
VPC-A
VPC-B
VPC-A is peered with VPC-C.
Peering-AC
VPC-A
VPC-C
Table 7 VPC route table details (IPv4)
Route Table
Destination
Next Hop
Route Type
rtb-VPC-A
172.16.0.0/24
Local
System
172.16.1.0/24
Local
System
Peering-AB
Custom
10.0.0.0/16 (VPC-C)
Peering-AC
Custom
Add a route with the CIDR block of VPC-C as the destination and Peering-AC as the next hop.
rtb-VPC-B
10.0.0.0/24
Local
System
172.16.0.0/16 (VPC-A)
Peering-AB
Custom
Add a route with the CIDR block of VPC-A as the destination and Peering-AB as the next hop.
rtb-VPC-C
10.0.0.0/24
Local
System
Peering-AC
Custom
Add a route with the CIDR block of VPC-A as the destination and Peering-AC as the next hop.
