Using a VPC Peering Connection to Connect Two VPCs
Scenario |
Scenario Description |
IP Address Version |
Example |
Two VPCs peered together |
You have two VPCs that require full access to each other's resources. For example, your company has VPC-A for the human resource department, and VPC-B for the finance department. The two departments require full access to each other's resources. |
IPv4 |
IPv6 |
Multiple VPCs peered together |
You have multiple VPCs that require access to each other's resources. For example, your company has VPC-A for the human resource department, VPC-B for the finance department, and VPC-C for the marketing department. These departments require full access to each other's resources. |
IPv4 |
IPv4 |
Multiple VPCs Peered Together Through Transitive Peering Connections (IPv4) |
IPv6 |
One central VPC peered with two VPCs |
You have a central VPC that requires access to two peer VPCs, and similarly, the peer VPCs require access to the central VPC. However, the two peer VPCs need to be isolated from each other. For example, public services (such as databases) are deployed on VPC-A. Both VPC-B and VPC-C need to access the databases, but they do not need to access each other. |
IPv4 |
IPv6 |
One central VPC with primary and secondary CIDR blocks peered with two VPCs |
You have a central VPC that has both primary and secondary CIDR blocks. The central VPC needs to communicate with two peer VPCs, but the peer VPCs need to be isolated from each other. |
IPv4 |
One Central VPC with Primary and Secondary CIDR Blocks Peered with Two VPCs (IPv4) |
One central VPC peered with multiple VPCs |
You have a central VPC that requires access to the multiple peer VPCs, and similarly, the peer VPCs require access to the central VPC. However, the peer VPCs need to be isolated from each other. For example, public services (such as databases) are deployed on your central VPC-A. VPC-B, VPC-C, VPC-D, VPC-E, VPC-F, and VPC-G need to access the databases, but these VPCs do not need to access each other. |
IPv4 |
IPv6 |
Notes and Constraints
If you create a VPC peering connection that connects entire CIDR blocks of two VPCs, the VPC CIDR blocks cannot overlap. Otherwise, the VPC peering connection does not take effect. For details, see Invalid VPC Peering for Overlapping VPC CIDR Blocks.
Even if you intend to use the VPC peering connection for IPv6 communication only, you cannot create a VPC peering connection if the VPCs have matching or overlapping IPv4 CIDR blocks. In all examples in this section, the IPv4 CIDR blocks of any VPCs connected by a VPC peering connection do not overlap.
Two VPCs Peered Together (IPv4)
VPC Name |
VPC CIDR Block |
Subnet Name |
Subnet CIDR Block |
Subnet Route Table |
ECS Name |
Security Group |
Private IP Address |
VPC-A |
172.16.0.0/16 |
Subnet-A01 |
172.16.0.0/24 |
rtb-VPC-A |
ECS-A01 |
sg-web: general-purpose web server |
172.16.0.111 |
Subnet-A02 |
172.16.1.0/24 |
rtb-VPC-A |
ECS-A02 |
172.16.1.91 |
VPC-B |
10.0.0.0/16 |
Subnet-B01 |
10.0.0.0/24 |
rtb-VPC-B |
ECS-B01 |
10.0.0.139 |
Subnet-B02 |
10.0.1.0/24 |
rtb-VPC-B |
ECS-B02 |
10.0.1.167 |
Peering Relationship |
Peering Connection Name |
Local VPC |
Peer VPC |
VPC-A is peered with VPC-B. |
Peering-AB |
VPC-A |
VPC-B |
Route Table |
Destination |
Next Hop |
Route Type |
Description |
rtb-VPC-A |
172.16.0.0/24 |
Local |
System |
Local routes are automatically added for communications within a VPC. |
172.16.1.0/24 |
Local |
System |
10.0.0.0/16 (VPC-B) |
Peering-AB |
Custom |
Add a route with the CIDR block of VPC-B as the destination and Peering-AB as the next hop. |
rtb-VPC-B |
10.0.0.0/24 |
Local |
System |
10.0.1.0/24 |
Local |
System |
172.16.0.0/16 (VPC-A) |
Peering-AB |
Custom |
Add a route with the CIDR block of VPC-A as the destination and Peering-AB as the next hop. |
If the destination of a route in a route table of a VPC is set to the CIDR block of a peer VPC and the CIDR blocks of the two VPCs do not overlap, the VPCs can have full access to each other's resources.
Two VPCs Peered Together (IPv6)
VPC Name |
VPC CIDR Block |
Subnet Name |
Subnet CIDR Block |
ECS Name |
Security Group |
VPC-A |
172.16.0.0/16 |
Subnet-A01 |
rtb-VPC-A |
ECS-A01 |
Subnet-A02 |
rtb-VPC-A |
ECS-A02 |
VPC-B |
10.0.0.0/16 |
Subnet-B01 |
rtb-VPC-B |
ECS-B01 |
Subnet-B02 |
rtb-VPC-B |
ECS-B02 |
Local VPC |
Peer VPC |
Peering-AB |
VPC-A |
VPC-B |
Route Table |
Destination |
Next Hop |
Route Type |
Description |
rtb-VPC-A |
172.16.0.0/24 |
Local |
System |
2407:c080:802:c34::/64 |
Local |
System |
172.16.1.0/24 |
Local |
System |
2407:c080:802:c37::/64 |
Local |
System |
Peering-AB |
Custom |
Add a route with the CIDR block of VPC-B as the destination and Peering-AB as the next hop for IPv4 communication. |
2407:c080:802:c35::/64 (Subnet-B01) |
Peering-AB |
Custom |
Add routes with the IPv6 CIDR blocks of Subnet-B01 and Subnet-B02 as the destinations and Peering-AB as the next hop for IPv6 communication. |
2407:c080:802:c38::/64 (Subnet-B02) |
Peering-AB |
Custom |
rtb-VPC-B |
10.0.0.0/24 |
Local |
System |
2407:c080:802:c35::/64 |
Local |
System |
10.0.1.0/24 |
Local |
System |
2407:c080:802:c38::/64 |
Local |
System |
Peering-AB |
Custom |
Add a route with the CIDR block of VPC-A as the destination and Peering-AB as the next hop for IPv4 communication. |
2407:c080:802:c34::/64 (Subnet-A01) |
Peering-AB |
Custom |
Add routes with the IPv6 CIDR blocks of Subnet-A01 and Subnet-A02 as the destinations and Peering-AB as the next hop for IPv6 communication. |
2407:c080:802:c37::/64 (Subnet-A02) |
Peering-AB |
Custom |
You can view IPv6 addresses of VPC subnets on the management console. To enable communication between entire CIDR blocks of two VPCs, you need to add routes with IPv6 CIDR blocks of all subnets in the VPCs as the destinations one by one.
Multiple VPCs Peered Together (IPv4)
VPC Name |
VPC CIDR Block |
Subnet Name |
Subnet CIDR Block |
ECS Name |
Security Group |
VPC-A |
172.16.0.0/16 |
Subnet-A01 |
172.16.0.0/24 |
rtb-VPC-A |
ECS-A01 |
172.16.0.111 |
Subnet-A02 |
172.16.1.0/24 |
rtb-VPC-A |
ECS-A02 |
172.16.1.91 |
VPC-B |
10.0.0.0/16 |
Subnet-B01 |
10.0.0.0/24 |
rtb-VPC-B |
ECS-B01 |
10.0.0.139 |
Subnet-B02 |
10.0.1.0/24 |
rtb-VPC-B |
ECS-B02 |
10.0.1.167 |
VPC-C |
192.168.0.0/16 |
Subnet-C01 |
192.168.0.0/24 |
rtb-VPC-C |
ECS-C01 |
192.168.0.194 |
Subnet-C02 |
192.168.1.0/24 |
rtb-VPC-C |
ECS-C02 |
192.168.1.200 |
Local VPC |
Peer VPC |
Peering-AB |
VPC-A |
VPC-B |
VPC-A is peered with VPC-C. |
Peering-AC |
VPC-A |
VPC-C |
VPC-B is peered with VPC-C. |
Peering-BC |
VPC-B |
VPC-C |
Route Table |
Destination |
Next Hop |
Route Type |
Description |
rtb-VPC-A |
172.16.0.0/24 |
Local |
System |
172.16.1.0/24 |
Local |
System |
Peering-AB |
Custom |
192.168.0.0/16 (VPC-C) |
Peering-AC |
Custom |
Add a route with the CIDR block of VPC-C as the destination and Peering-AC as the next hop. |
rtb-VPC-B |
10.0.0.0/24 |
Local |
System |
10.0.1.0/24 |
Local |
System |
Peering-AB |
Custom |
Peering-BC |
Custom |
Add a route with the CIDR block of VPC-C as the destination and Peering-BC as the next hop. |
rtb-VPC-C |
192.168.0.0/24 |
Local |
System |
192.168.1.0/24 |
Local |
System |
Peering-AC |
Custom |
Add a route with the CIDR block of VPC-A as the destination and Peering-AC as the next hop. |
Peering-BC |
Custom |
Add a route with the CIDR block of VPC-B as the destination and Peering-BC as the next hop. |
VPC peering connections are transitive. As shown in Figure 4, there is a VPC peering connection between VPC-A and VPC-B, and between VPC-A and VPC-C. To enable communication between VPC-B and VP-C, you can use either of the following methods:
- Create a VPC peering connection between VPC-B and VPC-C. For details, see Multiple VPCs Peered Together (IPv4).
- Add routes to direct traffic between VPC-B and VPC-C based on VPC-A. For details, see Table 13.
VPC Name |
VPC CIDR Block |
Subnet Name |
Subnet CIDR Block |
ECS Name |
Security Group |
VPC-A |
172.16.0.0/16 |
Subnet-A01 |
172.16.0.0/24 |
rtb-VPC-A |
ECS-A01 |
172.16.0.111 |
Subnet-A02 |
172.16.1.0/24 |
rtb-VPC-A |
ECS-A02 |
172.16.1.91 |
VPC-B |
10.0.0.0/16 |
Subnet-B01 |
10.0.0.0/24 |
rtb-VPC-B |
ECS-B01 |
10.0.0.139 |
Subnet-B02 |
10.0.1.0/24 |
rtb-VPC-B |
ECS-B02 |
10.0.1.167 |
VPC-C |
192.168.0.0/16 |
Subnet-C01 |
192.168.0.0/24 |
rtb-VPC-C |
ECS-C01 |
192.168.0.194 |
Subnet-C02 |
192.168.1.0/24 |
rtb-VPC-C |
ECS-C02 |
192.168.1.200 |
Local VPC |
Peer VPC |
Peering-AB |
VPC-A |
VPC-B |
Peering-AC |
VPC-A |
VPC-C |
Route Table |
Destination |
Next Hop |
Route Type |
Description |
rtb-VPC-A |
172.16.0.0/24 |
Local |
System |
172.16.1.0/24 |
Local |
System |
Peering-AB |
Custom |
Peering-AC |
Custom |
rtb-VPC-B |
10.0.0.0/24 |
Local |
System |
10.0.1.0/24 |
Local |
System |
Peering-AB |
Custom |
Peering-AB |
Custom |
Add a route with the CIDR block of VPC-C as the destination and Peering-AB as the next hop. |
rtb-VPC-C |
192.168.0.0/24 |
Local |
System |
192.168.1.0/24 |
Local |
System |
Peering-AC |
Custom |
Peering-AC |
Custom |
Add a route with the CIDR block of VPC-B as the destination and Peering-AC as the next hop. |
Multiple VPCs Peered Together (IPv6)
VPC Name |
VPC CIDR Block |
Subnet Name |
Subnet CIDR Block |
ECS Name |
Security Group |
VPC-A |
172.16.0.0/16 |
Subnet-A01 |
rtb-VPC-A |
ECS-A01 |
Subnet-A02 |
rtb-VPC-A |
ECS-A02 |
VPC-B |
10.0.0.0/16 |
Subnet-B01 |
rtb-VPC-B |
ECS-B01 |
Subnet-B02 |
rtb-VPC-B |
ECS-B02 |
VPC-C |
192.168.0.0/16 |
Subnet-C01 |
rtb-VPC-C |
ECS-C01 |
Subnet-C02 |
rtb-VPC-C |
ECS-C02 |
Local VPC |
Peer VPC |
Peering-AB |
VPC-A |
VPC-B |
Peering-AC |
VPC-A |
VPC-C |
Peering-BC |
VPC-B |
VPC-C |
Route Table |
Destination |
Next Hop |
Route Type |
Description |
rtb-VPC-A |
172.16.0.0/24 |
Local |
System |
Local |
System |
172.16.1.0/24 |
Local |
System |
Local |
System |
Peering-AB |
Custom |
Peering-AB |
Custom |
Peering-AB |
Custom |
Peering-AC |
Custom |
Add a route with the CIDR block of VPC-C as the destination and Peering-AC as the next hop for IPv4 communication. |
2407:c080:802:c3c::/64 (Subnet-C01) |
Peering-AC |
Custom |
Add routes with the IPv6 CIDR blocks of Subnet-C01 and Subnet-C02 as the destinations and Peering-AC as the next hop for IPv6 communication. |
2407:c080:802:c3d::/64 (Subnet-C02) |
Peering-AC |
Custom |
rtb-VPC-B |
10.0.0.0/24 |
Local |
System |
Local |
System |
10.0.1.0/24 |
Local |
System |
Local |
System |
Peering-AB |
Custom |
Peering-AB |
Custom |
Peering-AB |
Custom |
Peering-BC |
Custom |
Add a route with the CIDR block of VPC-C as the destination and Peering-BC as the next hop for IPv4 communication. |
Peering-BC |
Custom |
Add routes with the IPv6 CIDR blocks of Subnet-C01 and Subnet-C02 as the destinations and Peering-BC as the next hop for IPv6 communication. |
Peering-BC |
Custom |
rtb-VPC-C |
192.168.0.0/24 |
Local |
System |
2407:c080:802:c3c::/64 |
Local |
System |
192.168.1.0/24 |
Local |
System |
2407:c080:802:c3d::/64 |
Local |
System |
Peering-AC |
Custom |
Add a route with the CIDR block of VPC-A as the destination and Peering-AC as the next hop for IPv4 communication. |
Peering-AC |
Custom |
Add routes with the IPv6 CIDR blocks of Subnet-A01 and Subnet-A02 as the destinations and Peering-AC as the next hop for IPv6 communication. |
Peering-AC |
Custom |
Peering-BC |
Custom |
Add a route with the CIDR block of VPC-B as the destination and Peering-BC as the next hop for IPv4 communication. |
Peering-BC |
Custom |
Add routes with the IPv6 CIDR blocks of Subnet-B01 and Subnet-B02 as the destinations and Peering-BC as the next hop for IPv6 communication. |
Peering-BC |
Custom |
One Central VPC Peered with Two VPCs (IPv4)
VPC Name |
VPC CIDR Block |
Subnet Name |
Subnet CIDR Block |
ECS Name |
Security Group |
VPC-A |
172.16.0.0/16 |
Subnet-A01 |
172.16.0.0/24 |
rtb-VPC-A |
ECS-A01 |
172.16.0.111 |
Subnet-A02 |
172.16.1.0/24 |
rtb-VPC-A |
ECS-A02 |
172.16.1.91 |
VPC-B |
10.0.0.0/16 |
Subnet-B01 |
10.0.0.0/24 |
rtb-VPC-B |
ECS-B01 |
10.0.0.139 |
Subnet-B02 |
10.0.1.0/24 |
rtb-VPC-B |
ECS-B02 |
10.0.1.167 |
VPC-C |
192.168.0.0/16 |
Subnet-C01 |
192.168.0.0/24 |
rtb-VPC-C |
ECS-C01 |
192.168.0.194 |
Subnet-C02 |
192.168.1.0/24 |
rtb-VPC-C |
ECS-C02 |
192.168.1.200 |
Local VPC |
Peer VPC |
Peering-AB |
VPC-A |
VPC-B |
Peering-AC |
VPC-A |
VPC-C |
Route Table |
Destination |
Next Hop |
Route Type |
Description |
rtb-VPC-A |
172.16.0.0/24 |
Local |
System |
172.16.1.0/24 |
Local |
System |
Peering-AB |
Custom |
Peering-AC |
Custom |
rtb-VPC-B |
10.0.0.0/24 |
Local |
System |
10.0.1.0/24 |
Local |
System |
Peering-AB |
Custom |
rtb-VPC-C |
192.168.0.0/24 |
Local |
System |
192.168.1.0/24 |
Local |
System |
Peering-AC |
Custom |
One Central VPC Peered with Two VPCs (IPv6)
VPC Name |
VPC CIDR Block |
Subnet Name |
Subnet CIDR Block |
ECS Name |
Security Group |
VPC-A |
172.16.0.0/16 |
Subnet-A01 |
rtb-VPC-A |
ECS-A01 |
Subnet-A02 |
rtb-VPC-A |
ECS-A02 |
VPC-B |
10.0.0.0/16 |
Subnet-B01 |
rtb-VPC-B |
ECS-B01 |
Subnet-B02 |
rtb-VPC-B |
ECS-B02 |
VPC-C |
192.168.0.0/16 |
Subnet-C01 |
rtb-VPC-C |
ECS-C01 |
Subnet-C02 |
rtb-VPC-C |
ECS-C02 |
Local VPC |
Peer VPC |
Peering-AB |
VPC-A |
VPC-B |
Peering-AC |
VPC-A |
VPC-C |
Route Table |
Destination |
Next Hop |
Route Type |
Description |
rtb-VPC-A |
172.16.0.0/24 |
Local |
System |
Local |
System |
172.16.1.0/24 |
Local |
System |
Local |
System |
Peering-AB |
Custom |
Peering-AB |
Custom |
Peering-AB |
Custom |
Peering-AC |
Custom |
Peering-AC |
Custom |
Peering-AC |
Custom |
rtb-VPC-B |
10.0.0.0/24 |
Local |
System |
Local |
System |
10.0.1.0/24 |
Local |
System |
Local |
System |
Peering-AB |
Custom |
Peering-AB |
Custom |
Peering-AB |
Custom |
rtb-VPC-C |
192.168.0.0/24 |
Local |
System |
Local |
System |
192.168.1.0/24 |
Local |
System |
Local |
System |
Peering-AC |
Custom |
Peering-AC |
Custom |
Peering-AC |
Custom |
VPC Name |
VPC CIDR Block |
Subnet Name |
Subnet CIDR Block |
ECS Name |
Security Group |
VPC-A |
Primary CIDR block: 172.16.0.0/16 |
Subnet-A01 |
172.16.0.0/24 |
rtb-VPC-A |
ECS-A01 |
172.16.0.111 |
Secondary CIDR block: 192.167.0.0/16 |
Subnet-A-Extend01 |
192.167.0.0/24 |
rtb-VPC-A |
ECS-A-Extend01 |
192.167.0.100 |
VPC-B |
10.0.0.0/16 |
Subnet-B01 |
10.0.0.0/24 |
rtb-VPC-B |
ECS-B01 |
10.0.0.139 |
VPC-C |
192.168.0.0/16 |
Subnet-C01 |
192.168.0.0/24 |
rtb-VPC-C |
ECS-C01 |
192.168.0.194 |
Local VPC |
Peer VPC |
Peering-AB |
VPC-A |
VPC-B |
Peering-AC |
VPC-A |
VPC-C |
Route Table |
Destination |
Next Hop |
Route Type |
Description |
rtb-VPC-A |
172.16.0.0/24 |
Local |
System |
192.167.0.0/24 |
Local |
System |
Peering-AB |
Custom |
Peering-AC |
Custom |
rtb-VPC-B |
10.0.0.0/24 |
Local |
System |
172.16.0.0/16 (Primary CIDR block of VPC-A) |
Peering-AB |
Custom |
Add routes with the primary and secondary CIDR blocks of VPC-A as the destinations and Peering-AB as the next hop. |
192.167.0.0/16 (Secondary CIDR block of VPC-A) |
Peering-AB |
Custom |
rtb-VPC-C |
192.168.0.0/24 |
Local |
System |
Peering-AC |
Custom |
Add routes with the primary and secondary CIDR blocks of VPC-A as the destinations and Peering-AC as the next hop. |
Peering-AC |
Custom |
One Central VPC Peered with Multiple VPCs (IPv4)
VPC Name |
VPC CIDR Block |
Subnet Name |
Subnet CIDR Block |
ECS Name |
Security Group |
VPC-A |
172.16.0.0/16 |
Subnet-A01 |
172.16.0.0/24 |
rtb-VPC-A |
ECS-A01 |
172.16.0.111 |
Subnet-A02 |
172.16.1.0/24 |
rtb-VPC-A |
ECS-A02 |
172.16.1.91 |
VPC-B |
10.0.0.0/16 |
Subnet-B01 |
10.0.0.0/24 |
rtb-VPC-B |
ECS-B01 |
10.0.0.139 |
VPC-C |
192.168.0.0/16 |
Subnet-C01 |
192.168.0.0/24 |
rtb-VPC-C |
ECS-C01 |
192.168.0.194 |
VPC-D |
10.2.0.0/16 |
Subnet-D01 |
10.2.0.0/24 |
rtb-VPC-D |
ECS-D01 |
10.2.0.237 |
VPC-E |
10.3.0.0/16 |
Subnet-E01 |
10.3.0.0/24 |
rtb-VPC-E |
ECS-E01 |
10.3.0.87 |
VPC-F |
172.17.0.0/16 |
Subnet-F01 |
172.17.0.0/24 |
rtb-VPC-F |
ECS-F01 |
172.17.0.103 |
VPC-G |
10.4.0.0/16 |
Subnet-G01 |
10.4.0.0/24 |
rtb-VPC-G |
ECS-G01 |
10.4.0.10 |
Local VPC |
Peer VPC |
Peering-AB |
VPC-A |
VPC-B |
Peering-AC |
VPC-A |
VPC-C |
VPC-A is peered with VPC-D. |
Peering-AD |
VPC-A |
VPC-D |
VPC-A is peered with VPC-E. |
Peering-AE |
VPC-A |
VPC-E |
VPC-A is peered with VPC-F. |
Peering-AF |
VPC-A |
VPC-F |
VPC-A is peered with VPC-G. |
Peering-AG |
VPC-A |
VPC-G |
Route Table |
Destination |
Next Hop |
Route Type |
Description |
rtb-VPC-A |
172.16.0.0/24 |
Local |
System |
172.16.1.0/24 |
Local |
System |
Peering-AB |
Custom |
Peering-AC |
Custom |
10.2.0.0/16 (VPC-D) |
Peering-AD |
Custom |
Add a route with the CIDR block of VPC-D as the destination and Peering-AD as the next hop. |
10.3.0.0/16 (VPC-E) |
Peering-AE |
Custom |
Add a route with the CIDR block of VPC-E as the destination and Peering-AE as the next hop. |
172.17.0.0/16 (VPC-F) |
Peering-AF |
Custom |
Add a route with the CIDR block of VPC-F as the destination and Peering-AF as the next hop. |
10.4.0.0/16 (VPC-G) |
Peering-AG |
Custom |
Add a route with the CIDR block of VPC-G as the destination and Peering-AG as the next hop. |
rtb-VPC-B |
10.0.0.0/24 |
Local |
System |
Peering-AB |
Custom |
rtb-VPC-C |
192.168.0.0/24 |
Local |
System |
Peering-AC |
Custom |
rtb-VPC-D |
10.2.0.0/24 |
Local |
System |
Peering-AD |
Custom |
Add a route with the CIDR block of VPC-A as the destination and Peering-AD as the next hop. |
rtb-VPC-E |
10.3.0.0/24 |
Local |
System |
Peering-AE |
Custom |
Add a route with the CIDR block of VPC-A as the destination and Peering-AE as the next hop. |
rtb-VPC-F |
172.17.0.0/24 |
Local |
System |
Peering-AF |
Custom |
Add a route with the CIDR block of VPC-A as the destination and Peering-AF as the next hop. |
rtb-VPC-G |
10.4.0.0/24 |
Local |
System |
Peering-AG |
Custom |
Add a route with the CIDR block of VPC-A as the destination and Peering-AG as the next hop. |
One Central VPC Peered with Multiple VPCs (IPv6)
VPC Name |
VPC CIDR Block |
Subnet Name |
Subnet CIDR Block |
ECS Name |
Security Group |
VPC-A |
172.16.0.0/16 |
Subnet-A01 |
rtb-VPC-A |
ECS-A01 |
Subnet-A02 |
rtb-VPC-A |
ECS-A02 |
VPC-B |
10.0.0.0/16 |
Subnet-B01 |
rtb-VPC-B |
ECS-B01 |
VPC-C |
192.168.0.0/16 |
Subnet-C01 |
rtb-VPC-C |
ECS-C01 |
VPC-D |
10.2.0.0/16 |
Subnet-D01 |
rtb-VPC-D |
ECS-D01 |
VPC-E |
10.3.0.0/16 |
Subnet-E01 |
rtb-VPC-E |
ECS-E01 |
VPC-F |
172.17.0.0/16 |
Subnet-F01 |
rtb-VPC-F |
ECS-F01 |
VPC-G |
10.4.0.0/16 |
Subnet-G01 |
rtb-VPC-G |
ECS-G01 |
Local VPC |
Peer VPC |
Peering-AB |
VPC-A |
VPC-B |
Peering-AC |
VPC-A |
VPC-C |
Peering-AD |
VPC-A |
VPC-D |
Peering-AE |
VPC-A |
VPC-E |
Peering-AF |
VPC-A |
VPC-F |
Peering-AG |
VPC-A |
VPC-G |
Route Table |
Destination |
Next Hop |
Route Type |
Description |
rtb-VPC-A |
172.16.0.0/24 |
Local |
System |
Local |
System |
172.16.1.0/24 |
Local |
System |
Local |
System |
Peering-AB |
Custom |
Peering-AB |
Custom |
Add a route with the IPv6 CIDR block of Subnet-B01 as the destination and Peering-AB as the next hop for IPv6 communication. |
Peering-AC |
Custom |
Peering-AC |
Custom |
Add a route with the IPv6 CIDR block of Subnet-C01 as the destination and Peering-AC as the next hop for IPv6 communication. |
Peering-AD |
Custom |
Add a route with the CIDR block of VPC-D as the destination and Peering-AD as the next hop for IPv4 communication. |
2407:c080:802:c45::/64 (Subnet-D01) |
Peering-AD |
Custom |
Add a route with the IPv6 CIDR block of Subnet-D01 as the destination and Peering-AD as the next hop for IPv6 communication. |
Peering-AE |
Custom |
Add a route with the CIDR block of VPC-E as the destination and Peering-AE as the next hop for IPv4 communication. |
2407:c080:802:c46::/64 (Subnet-E01) |
Peering-AE |
Custom |
Add a route with the IPv6 CIDR block of Subnet-E01 as the destination and Peering-AE as the next hop for IPv6 communication. |
Peering-AF |
Custom |
Add a route with the CIDR block of VPC-F as the destination and Peering-AF as the next hop for IPv4 communication. |
2407:c080:802:c47::/64 (Subnet-F01) |
Peering-AF |
Custom |
Add a route with the IPv6 CIDR block of Subnet-F01 as the destination and Peering-AF as the next hop for IPv6 communication. |
Peering-AG |
Custom |
Add a route with the CIDR block of VPC-G as the destination and Peering-AG as the next hop for IPv4 communication. |
2407:c080:802:c48::/64 (Subnet-G01) |
Peering-AG |
Custom |
Add a route with the IPv6 CIDR block of Subnet-G01 as the destination and Peering-AG as the next hop for IPv6 communication. |
rtb-VPC-B |
10.0.0.0/24 |
Local |
System |
Local |
System |
Peering-AB |
Custom |
Peering-AB |
Custom |
Peering-AB |
Custom |
rtb-VPC-C |
192.168.0.0/24 |
Local |
System |
Local |
System |
Peering-AC |
Custom |
Peering-AC |
Custom |
Peering-AC |
Custom |
rtb-VPC-D |
10.2.0.0/24 |
Local |
System |
2407:c080:802:c45::/64 |
Local |
System |
Peering-AD |
Custom |
Add a route with the CIDR block of VPC-A as the destination and Peering-AD as the next hop for IPv4 communication. |
Peering-AD |
Custom |
Add routes with the IPv6 CIDR blocks of Subnet-A01 and Subnet-A02 as the destinations and Peering-AD as the next hop for IPv6 communication. |
Peering-AD |
Custom |
rtb-VPC-E |
10.3.0.0/24 |
Local |
System |
2407:c080:802:c46::/64 |
Local |
System |
Peering-AE |
Custom |
Peering-AE |
Custom |
Add routes with the IPv6 CIDR blocks of Subnet-A01 and Subnet-A02 as the destinations and Peering-AE as the next hop for IPv6 communication. |
Peering-AE |
Custom |
rtb-VPC-F |
172.17.0.0/24 |
Local |
System |
2407:c080:802:c47::/64 |
Local |
System |
Peering-AF |
Custom |
Peering-AF |
Custom |
Add routes with the IPv6 CIDR blocks of Subnet-A01 and Subnet-A02 as the destinations and Peering-AF as the next hop for IPv6 communication. |
Peering-AF |
Custom |
rtb-VPC-G |
10.4.0.0/24 |
Local |
System |
2407:c080:802:c48::/64 |
Local |
System |
Peering-AG |
Custom |
Peering-AG |
Custom |
Add routes with the IPv6 CIDR blocks of Subnet-A01 and Subnet-A02 as the destinations and Peering-AG as the next hop for IPv6 communication. |
Peering-AG |
Custom |
