Manually Configuring IPv4 and IPv6 Policy-based Routes for a Linux ECS with Multiple Network Interfaces (CentOS)
This section describes how to configure policy-based routes for a CentOS 8.0 64-bit ECS with two network interfaces.
- IPv4: If IPv4 communication between cloud servers with multiple network interfaces is required, you need to configure IPv4 routes by referring to Configuring IPv4 Policy-based Routes for a CentOS ECS.
- IPv6: If IPv6 communication between cloud servers with multiple network interfaces is required, you need to configure IPv6 routes by referring to Configuring IPv6 Policy-based Routes for a CentOS ECS.
- IPv4/IPv6 dual stack: If both IPv4 and IPv6 communications between cloud servers with multiple network interfaces are required, you need to configure both IPv4 and IPv6 routes by referring to Configuring IPv4 Policy-based Routes for a CentOS ECS and Configuring IPv6 Policy-based Routes for a CentOS ECS.
For details about the background knowledge and networking of an ECS with two network interfaces, see Overview.
- Collect the ECS network interface information required for configuring policy-based routes.
For details, see Collecting ECS Network Information.
In this example, the network information of the ECS is shown in Table 1.
- Log in to the source ECS.
For details, see How Do I Log In to My ECS?
- Check whether the source ECS can use its primary network interface to communicate with the destination ECS:
Before configuring policy-based routes, ensure that the source ECS can use its primary network interface to communicate with the destination ECS.
ping -I <IP-address-of-the-primary-network-interface-on-the-source-ECS> <IP-address-of-the-destination-ECS>
In this example, run the following command:
ping -I 10.0.0.115 10.0.2.12
If information similar to the following is displayed, the source ECS can use its primary network interface to communicate with the destination ECS.[root@ecs-resource ~]# ping -I 10.0.0.115 10.0.2.12 PING 10.0.2.12 (10.0.2.12) from 10.0.0.115 : 56(84) bytes of data. 64 bytes from 10.0.2.12: icmp_seq=1 ttl=64 time=0.775 ms 64 bytes from 10.0.2.12: icmp_seq=2 ttl=64 time=0.268 ms 64 bytes from 10.0.2.12: icmp_seq=3 ttl=64 time=0.220 ms 64 bytes from 10.0.2.12: icmp_seq=4 ttl=64 time=0.167 ms ^C --- 10.0.2.12 ping statistics ---
- Query the network interface names of the source ECS:
Search for the network interface names based on IP addresses.
- The primary network interface address is 10.0.0.115, and its name is eth0.
- The extended network interface address is 10.0.1.183, and its name is eth1.
[root@ecs-resource ~]# ifconfig eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 inet 10.0.0.115 netmask 255.255.255.0 broadcast 10.0.0.255 inet6 fe80::f816:3eff:fe92:6e0e prefixlen 64 scopeid 0x20<link> ether fa:16:3e:92:6e:0e txqueuelen 1000 (Ethernet) RX packets 432288 bytes 135762012 (129.4 MiB) RX errors 0 dropped 0 overruns 0 frame 1655 TX packets 423744 bytes 106716932 (101.7 MiB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 eth1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 inet 10.0.1.183 netmask 255.255.255.0 broadcast 10.0.1.255 inet6 fe80::f816:3eff:febf:5818 prefixlen 64 scopeid 0x20<link> ether fa:16:3e:bf:58:18 txqueuelen 1000 (Ethernet) RX packets 9028 bytes 536972 (524.3 KiB) RX errors 0 dropped 0 overruns 0 frame 1915 TX packets 6290 bytes 272473 (266.0 KiB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
- Configure temporary routes for the source ECS.
Temporary routes are applied immediately but are lost after ECS restart. To avoid network interruptions, perform 6 to configure permanent routes instead.
- Configure policy-based routes for both the primary and extended network interfaces.
- Primary network interface
ip route add default via <subnet-gateway> dev <network-interface-name> table <route-table-name>
ip route add <subnet-CIDR-block> dev <network-interface-name> table <route-table-name>
ip rule add from <network-interface-address> table <route-table-name>
- Extended network interface
Configure the parameters as follows:In this example, run the following commands:
ip route add default via 10.0.0.1 dev eth0 table 10
ip route add 10.0.0.0/24 dev eth0 table 10
ip rule add from 10.0.0.115 table 10
ip route add default via 10.0.1.1 dev eth1 table 20
ip route add 10.0.1.0/24 dev eth1 table 20
ip rule add from 10.0.1.183 table 20
If the ECS has multiple network interfaces, configure policy-based routes for all network interfaces one by one.
- Check whether the policy-based routes are added.
ip route show table <route-table-name-of-the-primary-network-interface>
ip route show table <route-table-name-of-the-extended-network-interface>
The route table name is the one configured in 5.a.
ip rule
ip route show table 10
ip route show table 20
If information similar to the following is displayed, the policy-based routes have been added.[root@ecs-resource ~]# ip rule 0: from all lookup local 32764: from 10.0.1.183 lookup 20 32765: from 10.0.0.115 lookup 10 32766: from all lookup main 32767: from all lookup default [root@ecs-resource ~]# ip route show table 10 default via 10.0.0.1 dev eth0 10.0.0.0/24 dev eth0 scope link [root@ecs-resource ~]# ip route show table 20 default via 10.0.1.1 dev eth1 10.0.1.0/24 dev eth1 scope link
- Check whether the source and destination ECSs can communicate with each other.
ping -I <IP-address-of-the-extended-network-interface-on-the-source-ECS> <IP-address-of-the-destination-ECS>
ping -I 10.0.1.183 10.0.2.12
If information similar to the following is displayed, both the network interfaces of the source ECS can communicate with the destination ECS.
[root@ecs-resource ~]# ping -I 10.0.0.115 10.0.2.12 PING 10.0.2.12 (10.0.2.12) from 10.0.0.115 : 56(84) bytes of data. 64 bytes from 10.0.2.12: icmp_seq=1 ttl=64 time=0.775 ms 64 bytes from 10.0.2.12: icmp_seq=2 ttl=64 time=0.268 ms 64 bytes from 10.0.2.12: icmp_seq=3 ttl=64 time=0.220 ms 64 bytes from 10.0.2.12: icmp_seq=4 ttl=64 time=0.167 ms ^C --- 10.0.2.12 ping statistics --- 4 packets transmitted, 4 received, 0% packet loss, time 102ms rtt min/avg/max/mdev = 0.167/0.357/0.775/0.244 ms [root@ecs-resource ~]# ping -I 10.0.1.183 10.0.2.12 PING 10.0.2.12 (10.0.2.12) from 10.0.1.183 : 56(84) bytes of data. 64 bytes from 10.0.2.12: icmp_seq=1 ttl=64 time=2.84 ms 64 bytes from 10.0.2.12: icmp_seq=2 ttl=64 time=0.258 ms 64 bytes from 10.0.2.12: icmp_seq=3 ttl=64 time=0.234 ms 64 bytes from 10.0.2.12: icmp_seq=4 ttl=64 time=0.153 ms ^C --- 10.0.2.12 ping statistics --- 4 packets transmitted, 4 received, 0% packet loss, time 92ms rtt min/avg/max/mdev = 0.153/0.871/2.840/1.137 ms
- Configure permanent routes for the source ECS.
- Run the following command to open the /etc/rc.local file:
vi /etc/rc.local
- Press i to enter the editing mode.
- Add the following content to the end of the file:
# check eth0 for ((x=0; x<10; x++)); do if (ip addr show eth0 | grep -w 10.0.0.115 >/dev/null 2>&1); then break fi sleep 1 done # Add v4 routes for eth0 ip route flush table 10 ip route add default via 10.0.0.1 dev eth0 table 10 ip route add 10.0.0.0/24 dev eth0 table 10 ip rule add from 10.0.0.115 table 10 # check eth1 for ((x=0; x<10; x++)); do if (ip addr show eth1 | grep -w 10.0.1.183 >/dev/null 2>&1); then break fi sleep 1 done # Add v4 routes for eth1 ip route flush table 20 ip route add default via 10.0.1.1 dev eth1 table 20 ip route add 10.0.1.0/24 dev eth1 table 20 ip rule add from 10.0.1.183 table 20 # Add v4 routes for cloud-init ip rule add to 169.254.169.254 table main
The parameters are as follows:
- check eth0: Check for the presence of the IP address 10.0.0.115 on primary network interface eth0 every second up to 10 times.
- Add v4 routes for eth0: Add policy-based routes for the primary network interface. Set the value to be the same as that configured in 5.a.
- check eth1: Check for the presence of the IP address 10.0.1.183 on extended network interface eth1 every second up to 10 times.
- Add v4 routes for eth1: Add policy-based routes for the extended network interface. Set the value to be the same as that configured in 5.a.
- Add v4 routes for cloud-init: Set the Cloud-Init address to the same value as that in this example.
- Press ESC to exit and enter :wq! to save the configuration.
- Run the following command to add execute permissions to the /etc/rc.local file:
chmod +x /etc/rc.local
If your operating system is Red Hat or EulerOS, run the following command after you perform 6.e:
chmod +x /etc/rc.d/rc.local
- Run the following command to restart the ECS:
Policy-based routes added to the /etc/rc.local file take effect only after the ECS is restarted. Ensure that workloads on the ECS will not be affected before restarting the ECS.
- Repeat 5.b to 5.c to check whether the policy-based routes are added and whether the source ECS and the destination ECS can communicate with each other.
Table 2 Linux ECSs using IPv6 addresses (CentOS) Type
Primary Network Interface
Extended Network Interface
Source
- IPv4 address: 10.0.0.102
- IPv6 address: 2407:c080:1200:1dd8:859c:e5d5:8b3d:a2d9
- Subnet IPv6 CIDR block: 2407:c080:1200:1dd8::/64
- Subnet IPv6 gateway: 2407:c080:1200:1dd8::1
- IPv4 address: 10.0.1.191
- IPv6 address: 2407:c080:1200:1a9c:7cc0:63b5:8e65:4dd8
- Subnet IPv6 CIDR block: 2407:c080:1200:1a9c::/64
- Subnet IPv6 gateway: 2407:c080:1200:1a9c::1
Destination
- IPv4 address: 10.0.2.3
- IPv6 address: 2407:c080:1200:1dd9:16a7:fe7a:8f71:7044
N/A
- Check whether the ECSs have IPv6 enabled and have IPv6 addresses.
Perform this step for both the source and destination ECSs to ensure that the ECSs have IPv6 addresses. Otherwise, the ECSs cannot communicate with each other using IPv6 addresses.
ECSs in this example run CentOS 8.0 64bit. For details about how to assign IPv6 addresses for ECSs running other OSs, see Linux (Manually Enabling Dynamic Assignment of IPv6 Addresses).
- Run the following command to check whether the ECS has IPv6 addresses:
In the following command output, eth0 and eth1 are the network interfaces of the ECS. Each network interface has one inet6 entry starting with fe80. This indicates that the ECS has IPv6 enabled but does not have IPv6 addresses assigned. In this case, perform 3.b to 3.g to obtain IPv6 addresses.
[root@ecs-resource ~]# ip addr ... 2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000 link/ether fa:16:3e:22:22:88 brd ff:ff:ff:ff:ff:ff inet 10.0.0.102/24 brd 10.0.0.255 scope global dynamic noprefixroute eth0 valid_lft 107943256sec preferred_lft 107943256sec inet6 fe80::f816:3eff:fe22:2288/64 scope link valid_lft forever preferred_lft forever 3: eth1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000 link/ether fa:16:3e:22:23:e1 brd ff:ff:ff:ff:ff:ff inet 10.0.1.191/24 brd 10.0.1.255 scope global dynamic noprefixroute eth1 valid_lft 107943256sec preferred_lft 107943256sec inet6 fe80::f816:3eff:fe22:23e1/64 scope link valid_lft forever preferred_lft forever
- The primary network interface address is 10.0.0.102, and its name is eth0.
- The extended network interface address is 10.0.1.191, and its name is eth1.
[root@ecs-resource ~]# ifconfig eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 inet 10.0.0.102 netmask 255.255.255.0 broadcast 10.0.0.255 inet6 fe80::f816:3eff:fe22:2288 prefixlen 64 scopeid 0x20<link> ether fa:16:3e:22:22:88 txqueuelen 1000 (Ethernet) RX packets 135116 bytes 132321802 (126.1 MiB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 60963 bytes 23201005 (22.1 MiB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 eth1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 inet 10.0.1.191 netmask 255.255.255.0 broadcast 10.0.1.255 inet6 fe80::f816:3eff:fe22:23e1 prefixlen 64 scopeid 0x20<link> ether fa:16:3e:22:23:e1 txqueuelen 1000 (Ethernet) RX packets 885 bytes 97676 (95.3 KiB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 47 bytes 4478 (4.3 KiB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
- Configure the ifcfg file of the primary network interface.
- Run the following command to open the ifcfg file of the primary network interface:
vi /etc/sysconfig/network-scripts/ifcfg-Primary network interface name
The name of the primary network interface is obtained in 3.b.
vi /etc/sysconfig/network-scripts/ifcfg-eth0
IPV6INIT="yes" DHCPV6C="yes"
- Configure the ifcfg file of the extended network interface.
- Run the following command to open the ifcfg file of the extended network interface:
vi /etc/sysconfig/network-scripts/ifcfg-Extended network interface name
The name of the extended network interface is obtained in 3.b.
vi /etc/sysconfig/network-scripts/ifcfg-eth1
- Edit the /etc/sysconfig/network file.
- Run the following command to open the /etc/sysconfig/network file:
NETWORKING_IPV6="yes"
- Run the following command to restart the network service for the configuration to take effect:
In the following command output, each network interface has an additional inet6 entry starting with 2407, followed by an entry starting with fe80. This indicates that the ECS has IPv6 addresses.
[root@ecs-resource ~]# ip addr ... 2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000 link/ether fa:16:3e:22:22:88 brd ff:ff:ff:ff:ff:ff inet 10.0.0.102/24 brd 10.0.0.255 scope global dynamic noprefixroute eth0 valid_lft 107999994sec preferred_lft 107999994sec inet6 2407:c080:1200:1dd8:859c:e5d5:8b3d:a2d9/128 scope global dynamic noprefixroute valid_lft 7195sec preferred_lft 7195sec inet6 fe80::f816:3eff:fe22:2288/64 scope link noprefixroute valid_lft forever preferred_lft forever 3: eth1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000 link/ether fa:16:3e:22:23:e1 brd ff:ff:ff:ff:ff:ff inet 10.0.1.191/24 brd 10.0.1.255 scope global dynamic noprefixroute eth1 valid_lft 107999994sec preferred_lft 107999994sec inet6 2407:c080:1200:1a9c:7cc0:63b5:8e65:4dd8/128 scope global dynamic noprefixroute valid_lft 7198sec preferred_lft 7198sec inet6 fe80::f816:3eff:fe22:23e1/64 scope link noprefixroute valid_lft forever preferred_lft forever
- Log in to the destination ECS and obtain an IPv6 address by performing operations from 3.a to 3.g.
- Log in to the source ECS and check whether it can use its primary network interface to communicate with the destination ECS:
ping6 -I <IP-address-of-the-primary-network-interface-on-the-source-ECS> <IP-address-of-the-destination-ECS>
ping6 -I 2407:c080:1200:1dd8:859c:e5d5:8b3d:a2d9 2407:c080:1200:1dd9:16a7:fe7a:8f71:7044
If information similar to the following is displayed, the source ECS can use its primary network interface to communicate with the destination ECS.[root@ecs-resource ~]# ping6 -I 2407:c080:1200:1dd8:859c:e5d5:8b3d:a2d9 2407:c080:1200:1dd9:16a7:fe7a:8f71:7044 PING 2407:c080:1200:1dd9:16a7:fe7a:8f71:7044(2407:c080:1200:1dd9:16a7:fe7a:8f71:7044) from 2407:c080:1200:1dd8:859c:e5d5:8b3d:a2d9 : 56 data bytes 64 bytes from 2407:c080:1200:1dd9:16a7:fe7a:8f71:7044: icmp_seq=1 ttl=64 time=0.635 ms 64 bytes from 2407:c080:1200:1dd9:16a7:fe7a:8f71:7044: icmp_seq=2 ttl=64 time=0.320 ms 64 bytes from 2407:c080:1200:1dd9:16a7:fe7a:8f71:7044: icmp_seq=3 ttl=64 time=0.287 ms 64 bytes from 2407:c080:1200:1dd9:16a7:fe7a:8f71:7044: icmp_seq=4 ttl=64 time=0.193 ms ^C --- 2407:c080:1200:1dd9:16a7:fe7a:8f71:7044 ping statistics --- 4 packets transmitted, 4 received, 0% packet loss, time 3074ms rtt min/avg/max/mdev = 0.193/0.358/0.635/0.167 ms
- Log in to the source ECS and configure temporary routes for the ECS.
ip -6 route add default via <subnet-gateway> dev <network-interface-name> table <route-table-name>
ip -6 route add <subnet-CIDR-block> dev <network-interface-name> table <route-table-name>
ip -6 rule add from <network-interface-address> table <route-table-name>
ip -6 route add default via 2407:c080:1200:1dd8::1 dev eth0 table 10
ip -6 route add 2407:c080:1200:1dd8::/64 dev eth0 table 10
ip -6 rule add from 2407:c080:1200:1dd8:859c:e5d5:8b3d:a2d9 table 10
ip -6 route add default via 2407:c080:1200:1a9c::1 dev eth1 table 20
ip -6 route add 2407:c080:1200:1a9c::/64 dev eth1 table 20
ip -6 rule add from 2407:c080:1200:1a9c:7cc0:63b5:8e65:4dd8 table 20
ip -6 route show table <route-table-name-of-the-primary-network-interface>
ip -6 route show table <route-table-name-of-the-extended-network-interface>
ip -6 rule
ip -6 route show table 10
ip -6 route show table 20
If information similar to the following is displayed, the policy-based routes have been added.[root@ecs-resource ~]# ip -6 rule 0: from all lookup local 32764: from 2407:c080:1200:1a9c:7cc0:63b5:8e65:4dd8 lookup 20 32765: from 2407:c080:1200:1dd8:859c:e5d5:8b3d:a2d9 lookup 10 32766: from all lookup main [root@ecs-resource ~]# ip -6 route show table 10 2407:c080:1200:1dd8::/64 dev eth0 metric 1024 pref medium default via 2407:c080:1200:1dd8::1 dev eth0 metric 1024 pref medium [root@ecs-resource ~]# ip -6 route show table 20 2407:c080:1200:1a9c::/64 dev eth1 metric 1024 pref medium default via 2407:c080:1200:1a9c::1 dev eth1 metric 1024 pref medium
ping -6 -I <IP-address-of-the-primary-network-interface-on-the-source-ECS> <IP-address-of-the-destination-ECS>
ping -6 -I <IP-address-of-the-extended-network-interface-on-the-source-ECS> <IP-address-of-the-destination-ECS>
ping -6 -I 2407:c080:1200:1dd8:859c:e5d5:8b3d:a2d9 2407:c080:1200:1dd9:16a7:fe7a:8f71:7044
ping -6 -I 2407:c080:1200:1a9c:7cc0:63b5:8e65:4dd8 2407:c080:1200:1dd9:16a7:fe7a:8f71:7044
If information similar to the following is displayed, both the network interfaces of the source ECS can communicate with the destination ECS.[root@ecs-resource ~]# ping -6 -I 2407:c080:1200:1dd8:859c:e5d5:8b3d:a2d9 2407:c080:1200:1dd9:16a7:fe7a:8f71:7044 PING 2407:c080:1200:1dd9:16a7:fe7a:8f71:7044(2407:c080:1200:1dd9:16a7:fe7a:8f71:7044) from 2407:c080:1200:1dd8:859c:e5d5:8b3d:a2d9 : 56 data bytes 64 bytes from 2407:c080:1200:1dd9:16a7:fe7a:8f71:7044: icmp_seq=1 ttl=64 time=0.770 ms 64 bytes from 2407:c080:1200:1dd9:16a7:fe7a:8f71:7044: icmp_seq=2 ttl=64 time=0.295 ms 64 bytes from 2407:c080:1200:1dd9:16a7:fe7a:8f71:7044: icmp_seq=3 ttl=64 time=0.245 ms ^C --- 2407:c080:1200:1dd9:16a7:fe7a:8f71:7044 ping statistics --- 3 packets transmitted, 3 received, 0% packet loss, time 2080ms rtt min/avg/max/mdev = 0.245/0.436/0.770/0.237 ms [root@ecs-resource ~]# ping -6 -I 2407:c080:1200:1a9c:7cc0:63b5:8e65:4dd8 2407:c080:1200:1dd9:16a7:fe7a:8f71:7044 PING 2407:c080:1200:1dd9:16a7:fe7a:8f71:7044(2407:c080:1200:1dd9:16a7:fe7a:8f71:7044) from 2407:c080:1200:1a9c:7cc0:63b5:8e65:4dd8 : 56 data bytes 64 bytes from 2407:c080:1200:1dd9:16a7:fe7a:8f71:7044: icmp_seq=1 ttl=64 time=0.922 ms 64 bytes from 2407:c080:1200:1dd9:16a7:fe7a:8f71:7044: icmp_seq=2 ttl=64 time=0.307 ms 64 bytes from 2407:c080:1200:1dd9:16a7:fe7a:8f71:7044: icmp_seq=3 ttl=64 time=0.174 ms ^C --- 2407:c080:1200:1dd9:16a7:fe7a:8f71:7044 ping statistics --- 3 packets transmitted, 3 received, 0% packet loss, time 2059ms rtt min/avg/max/mdev = 0.174/0.467/0.922/0.326 ms
vi /etc/rc.local
# check eth0 for ((x=0; x<10; x++)); do if (ip addr show eth0 | grep -w 2407:c080:1200:1dd8:859c:e5d5:8b3d:a2d9 >/dev/null 2>&1); then break fi sleep 1 done # Add v6 routes for eth0 ip -6 route flush table 10 ip -6 route add default via 2407:c080:1200:1dd8::1 dev eth0 table 10 ip -6 route add 2407:c080:1200:1dd8::/64 dev eth0 table 10 ip -6 rule add from 2407:c080:1200:1dd8:859c:e5d5:8b3d:a2d9 table 10 # check eth1 for ((x=0; x<10; x++)); do if (ip addr show eth1 | grep -w 2407:c080:1200:1a9c:7cc0:63b5:8e65:4dd8 >/dev/null 2>&1); then break fi sleep 1 done # Add v6 routes for eth1 ip -6 route flush table 20 ip -6 route add default via 2407:c080:1200:1a9c::1 dev eth1 table 20 ip -6 route add 2407:c080:1200:1a9c::/64 dev eth1 table 20 ip -6 rule add from 2407:c080:1200:1a9c:7cc0:63b5:8e65:4dd8 table 20
- check eth0: Check whether primary network interface eth0 has obtained an IPv6 address (2407:c080:1200:1dd8:859c:e5d5:8b3d:a2d9) every second up to 10 times.
- Add v6 routes for eth0: Add policy-based routes for the primary network interface. Set the value to be the same as that configured in 5.a.
- check eth1: Check whether extended network interface eth1 has obtained an IPv6 address (2407:c080:1200:1a9c:7cc0:63b5:8e65:4dd8) every second up to 10 times.
- Add v6 routes for eth1: Add policy-based routes for the extended network interface. Set the value to be the same as that configured in 5.a.
- Run the following command to assign execute permissions to the /etc/rc.local file:
