On this page
Viewing the Basic Information About a Network Interface
Updated on 2024-09-02 GMT+08:00
You can view basic information about your network interface on the management console, including the name, ID, type, VPC, attached instance, and associated security groups.
  2. Click in the upper left corner and select the desired region and project.
  3. Click in the upper left corner and choose Networking > Virtual Private Cloud.
    The Virtual Private Cloud page is displayed.
  4. In the navigation pane on the left, choose Virtual Private Cloud > Network Interfaces.
  5. On the Network Interfaces page, click the private IP address of the target network interface.
Other Operations
On the network interface details page, you can also modify the following information:
  • You can edit the network interface name, change IP addresses, and attach the network interface to or detach it from an instance.
  • Enable or disable Instance-dependent Deletion.
    • Instance-dependent Deletion is disabled by default. The network interface will not be deleted if it is detached from the instance or if the instance is deleted. You can attach the network interface to another instance.
    • If Instance-dependent Deletion has been enabled, the network interface will be deleted after it is detached from the instance.
    The Instance-dependent Deletion option is only available in certain regions. See which regions support this option on the console.
