Updated on 2025-04-23 GMT+08:00
Creating a Network Interface
A primary network interface is created together with an instance by default. You can perform the following operations to create extended network interfaces on the Network Interfaces console.
Notes and Constraints
An extended network interface created on the console can only be attached to an instance from the same VPC, but they can be associated with different security groups.
If you create an extended network interface using an API, the interface can be attached to an instance from a different VPC.
  1. Go to the network interface list page.
  2. Click Create Network Interface.
  3. Configure parameters for the network interface, as shown in Table 1.
    Table 1 Parameter descriptions
    Parameter Description
    Example Value
    Region
    Region where the network interface is created. Select the region nearest to you to ensure the lowest latency possible.
    CN-Hong Kong
    Name
    Name of the network interface. The name:
    • Can contain 1 to 64 characters.
    • Can contain letters, digits, underscores (_), hyphens (-), and periods (.).
    networkInterface-891e
    VPC
    VPC where the network interface is created.
    vpc-001
    Subnet
    Subnet where the network interface is created.
    subnet-001
    IPv4 Address
    How a private IPv4 address will be assigned to the network interface. There are two options:
    • Automatically assign IP address: The system assigns a private IPv4 from the subnet.
    • Manually specify IP address: You can specify an IP address.
      If you select Manually specify IP address, enter a private IPv4 address.
    192.168.0.15
    Security Group
    Security group that will be associated with the network interface.
    sg-001
  4. Click OK.
