Help Center/Virtual Private Cloud/User Guide/Traffic Mirroring/Mirror Filters/Modifying the Basic Information About a Mirror Filter
Updated on 2025-04-23 GMT+08:00
You can modify basic information about a mirror filter, including its name and description.
  1. Go to the mirror filter list page.
  2. Locate the target mirror filter and click its name.
    The Inbound Rules tab is displayed.
  3. Click the Basic Information tab and modify parameters as prompted.
    1. Click next to the parameter to be modified and enter information in the text box.
    2. Click to save the modification.
    Table 1 Parameters that can be modified
    Example Value
    Name
    Mandatory
    Enter a different name for the mirror filter. The name:
    • Can contain 1 to 64 characters.
    • Can contain letters, digits, underscores (_), hyphens (-), and periods (.).
    mirror-filter-01
    Optional
    Enter a description for the mirror filter in the text box as required.
