Creating a Mirror Filter
A VPC traffic mirror filter is a set of inbound and outbound rules that control which traffic the mirror source sends or receives. Each rule can include matching criteria such as priority and action. You can create a mirror filter by referring to the following instructions.
- Inbound rules match the traffic received by a mirror source.
- Outbound rules match the traffic sent by a mirror source.
A mirror filter takes effect only after it is associated with mirror sessions.
Mirror Filter Rule Examples
| Direction | Priority | Protocol | Action | Type | Source | Source Port Range | Destination | Destination Port Range | Filtering Description |
| Inbound | 1 | TCP | Accept | IPv4 | 172.16.0.0/24 | 10000-10001 | 10.0.0.3/32 | 80-80 | If traffic enters a network interface of the mirror source, the mirror session will mirror packets that meet the following rule: TCP (IPv4) packets from source 172.16.0.0/24 over port 10000 or 10001 to destination 10.0.0.3/32 over port 80 |
| Outbound | 1 | All | Reject | IPv4 | 192.168.0.0/24 | All | 10.2.0.0/24 | All | If traffic leaves a network interface of the mirror source, the mirror session will not mirror packets that meet the following rule: IPv4 packets from source 192.168.0.0/24 over any port to destination 10.2.0.0/24 over any port. |
- Go to the mirror filter list page.
- In the upper right corner of the mirror filter list, click Create Mirror Filter.
The Create Mirror Filter page is displayed.
- Set basic information about the mirror filter as prompted.
Table 2 Parameters for configuring basic information Parameter
Example Value
Name
Mandatory
Enter the name of the mirror filter. The name:- Must contain 1 to 64 characters.
- Can contain letters, digits, underscores (_), hyphens (-), and periods (.).
mirror-filter-01
Optional
Enter the description of the mirror filter in the text box as required.
- Click Add Rule in the Inbound Rules area to add inbound rules. You can click
to add more inbound rules. Table 3 Inbound rule parameter description Parameter
Example Value
Priority
Priority of a mirror filter rule.- A priority value can be from 1 to 65535. A smaller value indicates a higher priority.
- Priorities of inbound rules must be unique for each mirror filter.
A mirror filter can contain multiple rules and the rules are matched in ascending order of priority.
For details, see the matching process of mirror filter rules.
Protocol
Select a network protocol.- If you select TCP, you can customize the source and destination port ranges.
- If you select UDP, you can customize the source and destination port ranges.
- If you set Type to IPv4 and select ICMP, all ports are specified for source and destination port ranges by default.
- If you set Type to IPv6 and select ICMPv6, all ports are specified for source and destination port ranges by default.
- If you select All, all network protocols are supported and all ports are specified for source and destination port ranges by default.
TCP
Action
Whether to accept or reject inbound traffic of a mirror source.- If you set Action to Accept, the traffic will be mirrored to the mirror target.
- If you set Action to Reject, the traffic will not be mirrored to the mirror target.
Accept
Type
IP address version of inbound traffic. You can specify:- IPv4
- IPv6
IPv4
Source
Source of inbound traffic. You can enter:- A single IP address: IP address/mask
Example IPv4 address: 192.168.10.10/32
Example IPv6 address: 2002:50::44/128
- An IP address range in CIDR notation: IP address/mask
Example IPv4 address range: 192.168.52.0/24
Example IPv6 address range: 2407:c080:802:469::/64
- All IP addresses
0.0.0.0/0 represents all IPv4 addresses.
::/0 represents all IPv6 addresses.
10.0.0.0/24
Source Port Range
Source port range of inbound traffic.- Port range: 1 to 65535
- Port range: Use a hyphen (-) to connect the start port and the end port, for example, 22-23. The end port cannot be smaller than the start port.
- All ports: Leave it empty or enter 1-65535.
22-23
Destination
Destination of inbound traffic. You can enter:- A single IP address: IP address/mask
- All IP addresses
0.0.0.0/0
Destination port range of inbound traffic.- Port range: 1 to 65535
1-65535
Enter the description of the mirror filter rule in the text box as required.
- Click OK.
- Click Add Rule in the Outbound Rules area to add outbound rules. You can click
to add more outbound rules. Table 4 Outbound rule parameter description Parameter
Example Value
Priority
Protocol
All
Action
Whether to accept or reject outbound traffic of a mirror source.- If you set Action to Accept, the traffic will be mirrored to the mirror target.
Reject
Type
IP address version of outbound traffic. You can specify:- IPv4
- IPv6
IPv4
Source
Source of outbound traffic. You can enter:- A single IP address: IP address/mask
- All IP addresses
192.168.0.0/24
Source Port Range
Source port range of outbound traffic.
All
Destination
Destination of outbound traffic. You can enter:- A single IP address: IP address/mask
- All IP addresses
10.2.0.0/24
Destination port range of outbound traffic.- Port range: 1 to 65535
All
- Click OK.
- After setting the parameters, click Create Now.
The mirror filter list page is displayed.
Follow-up Operations
- If you have no mirror session, refer to Creating a Mirror Session.
- If you have a mirror session and want to change the mirror filter of the mirror session, refer to Changing the Mirror Filter for a Mirror Session.
