Binding or Unbinding a Global Connection Bandwidth to and from an Edge Connection
This section describes how to bind or unbind a global connection bandwidth to or from an edge connection.
- Binding a Global Connection Bandwidth to an Edge Connection: Bind a global connection bandwidth to an edge connection to enable resources from the central and edge subnets to communicate with each other.
- Unbinding a Global Connection Bandwidth from an Edge Connection: Ensure that no services are running on an edge connection before unbinding its global connection bandwidth.
In addition, you can modify the global connection bandwidth name and size by referring to Modifying the Global Connection Bandwidth of an Edge Connection.
- Go to the edge gateway list page.
- Click the edge gateway name.
- Click the Edge Connections tab. In the edge connection list, search for or locate the edge connection.
- Click Bind Global Connection Bandwidth on the right of the target edge connection.
A confirmation dialog box is displayed.
- Select a global connection bandwidth as prompted and click OK.
If there is no global connection bandwidth, you can purchase one by referring to .Buying a Global Connection Bandwidth
- Check whether the binding is successful. If the Bind Global Connection Bandwidth button on the right of the target edge connection turns gray, the binding is successful.
- Locate the target edge connection and click More > Unbind Global Connection Bandwidth in the Operation column.
- Confirm the information and click OK.
- Check whether the unbinding is successful. If the Bind Global Private Bandwidth on the right of the target edge connection turns black, the unbinding is successful.
You can modify the global connection bandwidth name and size.
For details, see Modifying a Global Connection Bandwidth.
