Associating VPCs with or Disassociating VPCs from an Edge Gateway
- Associating VPCs with an Edge Gateway: You can associate one or more VPCs with an edge gateway at a time. The number of VPCs that can be associated with an edge gateway depends on the gateway edition:
- Disassociating VPCs from an Edge Gateway: You can disassociate one or more VPCs from an edge gateway at a time. Ensure that there are no services running in these VPCs before proceeding with the disassociation.
- Go to the edge gateway list page.
- In the edge gateway list, search for or locate the edge gateway.
- Click the edge gateway name.
- Click the VPCs tab and click Associate.
The Associate VPC dialog box is displayed.
- In the VPC list, select one or more VPCs and click OK.
On the VPCs tab, you can view the VPCs associated with the edge gateway.
- Click the VPCs tab. In the VPC list, disassociate VPCs.
- Disassociating a single VPC:
- In the VPC list, locate the target VPC and click Disassociate in the Operation column.
A confirmation dialog box is displayed.
- Confirm the information and click OK.
The disassociated VPCs are not displayed in the VPC list.
- Disassociating multiple VPCs:
- In the VPC list, select the VPCs to be disassociated and click Disassociate in the upper left corner of the VPC list.
