Deleting One or More Network ACL Rules
You can delete network ACL rules if you no longer need them.
Deleting rules may affect how and where traffic is directed. Be careful with this operation as it may interrupt services.
To delete a network ACL rule, see Deleting a Network ACL Rule.
- If there are a small number of rules to be deleted, you can select these rules in the network ACL rule list on the console by referring to Deleting Network ACL Rules in Batches (Manually Selecting Rules on the Console).
- If there are a large number of rules to be deleted, you can export the rule list to a local Excel file, only keep the rules you want to delete, and import the file to the console. The system then selects the rules to be processed based on the imported file. For details, see Deleting Network ACL Rules in Batches (Using an Excel File).
Notes and Constraints
Default network ACL rules cannot be modified or deleted.
A maximum of 50 network ACL rules can be deleted at a time.
- Go to the network ACL list page.
- In the network ACL list, locate the target network ACL and click its name.
The network ACL summary page is displayed.
- Click the Inbound Rules or Outbound Rules tab as required.
The network ACL rule list is displayed.
- In the network ACL rule list, locate the target rule and click Delete in the Operation column.
A confirmation dialog box is displayed.
- Confirm the information and click OK.
- In the network ACL rule list, select multiple rules and click Delete in the upper left corner above the list.
- In the upper left corner above the Network ACL rule list, click Batch Select.
The Batch Select dialog box is displayed.
- Select either of the following methods:
- Method 1: Click Download Template to download the Excel file to your local PC and fill in the network ACL rules to be enabled or disabled in the file.
- Method 2: Export the existing rules to a local Excel file, filter the target rules and keep them as they are, and save the file.
After the Excel file is ready, take step 6. The system then automatically selects the target rules based on the imported file.
- In the Batch Select dialog box, click Add. The system starts to match the rules in the Excel file against existing network ACL rules based on the type, action, protocol, source, source port range, destination, and destination port range.
- If a rule in the Excel file matches an existing network ACL rule, Verified is displayed in the Result column. Only the matched rules can be enabled or disabled.
- If a rule fails to be matched, the causes will be displayed in the Result column. The possible causes are as follows:
- There is no such rule in this network ACL.
- Inconsistent rule direction. For example, you perform the operation on outbound rules on the Inbound Rules tab, or the other way around.
- Duplicate rules in the Excel file. The system automatically filters out the duplicate rules.
- Confirm the rules and click OK.
The network ACL rule list page is displayed and the target rules are selected automatically.
- Click Delete above the network ACL rule list.
