Updated on 2026-09-18 GMT+08:00
Modifying IP Address Entries in an IP Address Group
This section describes how to modify IP addresses, IP address ranges, and their descriptions in an IP address group.
If an IP address group has resources associated, modifying IP address entries in an IP address group may affect your network communications.
If an IP address group has security groups and network ACLs associated, the rules associated with the IP address group will change.
  1. Go to the IP address group list page.
  2. In the IP address group list, click the name of the target IP address group.
    The basic information page of the IP address group is displayed.
  3. In the left corner above the IP address entry list, click Modify.
    The dialog box for modifying an IP address entry is displayed.
  4. Modify the information as prompted.
    For details, see Table 1.
    Table 1 Parameters for modifying IP address entries
    Example Value
    Name
    The name of the IP address group.
    ipGroup-A
    Max. Entries
    Mandatory
    You can specify the maximum number of IP address entries that can be added to an IP address group. The system shows the default upper limit. You can retain the default value if no change is required, or lower it if needed.
    If you want to increase the maximum number of IP address entries in a group, submit a service ticket.
    20
    IP Address Version
    IP address version supported by an IP address group. You can select an IP address version when you create an IP address group. IP address version cannot be modified after the IP address group is created. The supported versions are as follows:
    • IPv4
    • IPv6
    IPv4
    IP Address Entries
    You can modify existing IP addresses, IP address ranges, and their descriptions in an IP address group.
    The format is "IP address | Description". Description is optional, can contain 0 to 255 characters, and cannot contain angle brackets (< or >). You can enter:
    • An IPv4 address range, for example, 192.168.0.0/16 or 192.168.0.0/16 | ECS01
    • A single IPv4 address, for example, 192.168.10.10 or 192.168.10.10 | ECS01
    • An IPv6 address range, for example, 2001:db8:a583:6e::/64 or 2001:db8:a583:6e::/64 | ECS01
    • A single IPv6 address, for example, 2001:db8:a583:6e::5c or 2001:db8:a583:6e::5c | ECS01
    • Without description: 192.168.0.0/16
    • With description: 192.168.0.0/16 | ECS01
  5. Click OK.
    The IP address list is displayed and you can view that the IP address entry was modified.
