Updated on 2025-08-27 GMT+08:00
Managing IP Address Group Tags
Tags help you identify, classify, and search for IP address groups. You can perform the following operations to manage the tags of an IP address group:
  • Add an IP address group tag.
  • Modify an IP address group tag.
  • Delete an IP address group tag.
For details about IP address group tag requirements, see Table 1.
Table 1 IP address group tag key and value requirements
Requirements
Example Value
Tag key
  • For each resource, each tag key must be unique, and each tag key can only have one tag value.
  • Cannot be left blank.
  • Can contain a maximum of 128 characters.
  • Cannot start or end with a space.
test
Tag value
  • Can be left blank.
  • Can contain a maximum of 255 characters.
01
Notes and Constraints
Each cloud resource can have a maximum of 20 tags.
  1. Go to the IP address group list page.
  2. On the Tags tab, click Edit Tag in the upper left corner above the tag list.
    The Edit Tag dialog box is displayed.
  3. Perform the following operations on the tag as required:
    • Adding a tag: Click , enter a tag key and value, and click OK.
    • Modifying a tag: Click next to the target tag key or value, delete the original value, enter a new value, and click OK.
    • Deleting a tag: Click Delete next to the target tag and click OK.
