Modifying an IP Address Group
- Name
- Description
- Go to the IP address group list page.
- In the IP address group list, click the hyperlink of the IP address group name.
The basic information page of the IP address group is displayed.
- On the Basic Information tab page of the IP address group, click
on the right of the target parameter and modify the parameter as prompted. For details, see Table 1.Table 1 IP address group parameters Parameter
Example Value
Name
Mandatory
Enter the name of the IP address group. The name:
- Can contain 1 to 64 characters.
- Can contain letters, digits, underscores (_), hyphens (-), and periods (.).
You can customize the name of an IP address group that is uniquely identified by its ID.
ipGroup-A
Max. Entries
Mandatory
You can specify the maximum number of IP address entries that can be added to an IP address group. The system shows the default upper limit. You can retain the default value if no change is required, or lower it if needed.
If you want to increase the maximum number of IP address entries in a group, submit a service ticket.
20
Optional
Enter the description of the IP address group in the text box as required.
- Click
