Creating an IP Address Group
This section describes how to create an IP address group. An IP address group is a collection of IP addresses that can be associated with security groups and network ACLs to simplify IP address configuration and management.
- Go to the Create IP Address Group page.
- Configure the parameters as prompted. For details, see Table 1.
Table 1 Parameters for creating an IP address group Parameter
Example Value
Region
Mandatory
Regions are geographic areas isolated from each other. For low network latency and quick resource access, select the region nearest to where your services will be accessed.
An IP address group can be associated only with resources in the same region.
Region A
Name
Mandatory
Enter the name of the IP address group. The name:
- Can contain 1 to 64 characters.
- Can contain letters, digits, underscores (_), hyphens (-), and periods (.).
You can customize the name of an IP address group that is uniquely identified by its ID.
ipGroup-A
Enterprise Project
Mandatory
When creating an IP address group, you can add the group to an enabled enterprise project.
An enterprise project facilitates project-level management and grouping of cloud resources and users. The default project is default.
For details about creating and managing enterprise projects, see the Enterprise Management User Guide.
default
Description (Optional)
Optional
Enter the description of the IP address group in the text box as required.
Max. Entries
Mandatory
You can specify the maximum number of IP address entries that can be added to an IP address group. The system shows the default upper limit. You can retain the default value if no change is required, or lower it if needed.
If you want to increase the maximum number of IP address entries in a group, submit a service ticket.
20
IP Address Version
Mandatory
Select the type of IP addresses that can be added to an IP address group.- IPv4
- IPv6
IPv4
Creation Method
Mandatory
How an IP address group is created. There are two options:- Create new: You need to enter IP address entries.
- Copy from another group: You can copy all IP address entries from another IP address group to the current IP address group. Cross-region replication is supported.
Create new
Region of IP Address Group to Be Copied
This parameter is mandatory if Creation Method is set to Copy from another group.
Select the region where the IP address group to be copied is located from the drop-down list.
Region A
Select the IP address group to be copied from the drop-down list.
ipGroup-B
IP Address Entries
Optional
Enter an IP address or IP address range on each line, and press Enter.
The format is "IP address | Description". Description is optional, can contain 0 to 255 characters, and cannot contain angle brackets (< or >). You can enter:- An IPv4 address range, for example, 192.168.0.0/16 or 192.168.0.0/16 | ECS01
- A single IPv4 address, for example, 192.168.10.10 or 192.168.10.10 | ECS01
- An IPv6 address range, for example, 2001:db8:a583:6e::/64 or 2001:db8:a583:6e::/64 | ECS01
- A single IPv6 address, for example, 2001:db8:a583:6e::5c or 2001:db8:a583:6e::5c | ECS01
- Without description: 192.168.0.0/16
- With description: 192.168.0.0/16 | ECS01
- Click Create Now.
The IP address group list is displayed. The status of the created IP address group is Normal.
IP address groups need to be associated with resources. For example, if an IP address group is associated with a security group, the IP address group can be selected as the source or destination when you add a security group rule. For details, see Associating an IP Address Group with a Security Group or Network ACL.
