Updated on 2026-03-03 GMT+08:00
Access Control Overview
A VPC is your private network on the cloud. You can configure access control rules to ensure the security of instances, such as ECSs, databases, and cloud containers, running in a VPC.
  • A security group protects the instances in it.
  • Network ACLs provide an optional layer of security for your subnets and control the traffic entering and leaving their associated subnets. Compared with a security group that protects instances, a network ACL can protect an entire subnet when its rules are correctly configured. This allows all instances in a subnet to be protected.
  • Cloud Firewall scrubs traffic between VPCs, between VPCs and the Internet, and between VPCs and on-premises data centers, securing access to services. Cloud firewalls offer broader protection compared to security groups and network ACLs.
Figure 1 shows how security groups, network ACLs, and cloud firewalls are used. In this example:
  • Security groups Sg-A and Sg-B control the traffic entering and leaving their ECSs.
  • Network ACL Fw-A protects all ECSs in Subnet-A01, while network ACL Fw-B protects all ECSs in Subnet-A02 and Subnet-B01. Network ACLs and security groups are used together to enhance service security.
  • Cloud firewalls
    • Scrubbing traffic between a VPC and the Internet: The ECS accesses the Internet over EIP-A. Cloud firewall CFW-A scrubs the traffic from the ECS to the Internet.
    • Scrubbing traffic between different VPCs: VPC-A and VPC-B are connected through enterprise router ER-X. Cloud firewall CFW-B scrubs the traffic between the two VPCs.
    • Scrubbing traffic between a VPC and an on-premises data center: VPC-A and the on-premises data center are connected through enterprise router ER-X and Direct Connect connection DC-A. Cloud firewall CFW-B scrubs the traffic from VPC-A to DC-A, and then the scrubbed traffic is forwarded to the on-premises data center.
Figure 1 VPC access control
Differences Between Access Control Options
Table 1 provides differences between access control options. You can select one or more as needed.
Table 1 Differences between access control options
Item
Security Group
Network ACL
Protection Scope
Protects instances in a security group, such as ECSs, databases, and cloud containers.
Protects subnets and all the instances in the subnets.
Scrubs traffic between VPCs, between VPCs and the Internet, and between VPCs and on-premises data centers, securing access to services.
Mandatory or Optional
Mandatory. Instances must be added to at least one security group.
Optional. You can determine whether to associate a subnet with a network ACL based on service requirements.
Optional. You can determine whether to enable VPC border firewalls based on service requirements.
Billed or Free
Free
Free
Billed
Stateful or Not
Stateful. The response traffic of inbound and outbound requests is allowed to leave and enter an instance.
Stateful. The response traffic of inbound and outbound requests is allowed to leave and enter a subnet.
Stateful. The response traffic of inbound and outbound requests is allowed to leave and enter the Internet, a VPC, or Direct Connect connection.
Action
Supports both Allow and Deny rules.
  • Allow: allows the matched traffic to enter or leave the instances.
  • Deny: denies the matched traffic to enter or leave the instances.
  • Allow: allows the matched traffic to enter or leave the subnet.
  • Deny: denies the matched traffic to enter or leave the subnet.
Supports both Allow and Block rules.
Allow: allows matched traffic to enter or leave the Internet, a VPC, or Direct Connect connection.
Block: denies matched traffic to enter or leave the Internet, a VPC, or Direct Connect connection.
Rule Packets
Supports packet filtering based on 3-tuple (protocol, port, and source/destination address).
Supports packet filtering based on 5-tuple (protocol, source port, destination port, source address, and destination address).
Supports packet filtering based on 5-tuple (protocol, source port, destination port, source address, and destination address), domain name, IP geolocation, and Layer 7 protocol.
Matching Rule
If an instance is associated with multiple security groups that have multiple rules:
  1. Rules are first matched based on how early a security group is associated with an instance. The security group associated earlier takes precedence over those associated later.
  2. Rules are then matched by priority in that security group. A rule with a smaller priority value has a higher priority.
  3. Deny rules take precedence over allow rules if the rules have the same priority.
A subnet can have only one network ACL associated. If there are multiple rules in a network ACL, they are matched in ascending order, from the lowest to highest rule number.
If there are multiple rules configured for a cloud firewall, the rules are matched based on their priorities. A smaller value indicates a higher priority.
Usage
  • When creating an instance, for example, an ECS, you must select a security group. If there is no security group available, the ECS will be associated with the default security group.
  • After creating an instance, you can:
    • Add or remove the instance to or from a security group on the security group console.
    • Add or remove the instance to or from a security group on the instance console.
Selecting a network ACL is not allowed when you create a subnet. You must create a network ACL, add inbound and outbound rules, associate subnets with the network ACL, and enable the network ACL. The network ACL then protects the associated subnets and instances in the subnets.
Create a cloud firewall (professional edition) and configure an enterprise router to direct traffic to the cloud firewall. Configure protection rules to allow or block the traffic. CFW provides different features, such as intrusion prevention system (IPS) and antivirus, to scrub the allowed traffic.
If you need to use advanced protection capabilities (such as access control, IPS, and antivirus based on domain names, geographical locations, and schedules), or your services have high-level protection requirements, you can use Cloud Firewall.
How Traffic Matches Security Group and Network ACL Rules
If both security group and network ACL rules are configured, traffic matches network ACL rules first and then security group rules. Figure 2 describes how inbound traffic matches security group and network ACL rules.
  1. Traffic first matches network ACL rules.
    • If the traffic does not match any rule, the default rule is applied, and traffic to the subnet is denied.
    • If the traffic matches a rule, the rule is applied, which determines where the traffic will go.
      • If Action is set to Deny, the traffic to the subnet is denied.
      • If Action is set to Allow, the traffic to the subnet is allowed.
  2. The traffic continues to match the security group rules.
    1. If an instance is associated with multiple security groups, the traffic first matches rules in the security group with the lowest sequence number.
      1. If the traffic does not match any rule, it is denied to access the instances.
      2. If the traffic matches a rule, the rule determines where the traffic will go.
        • If Action is set to Deny, the traffic is denied to access the instances.
        • If Action is set to Allow, the traffic is allowed to access the instances.
    2. If the traffic fails to match the rules in the first security group, it continues to match the rules in the second security group.
    3. If the traffic does not match the rules in any security group, the traffic is denied.
Figure 2 How traffic matches security group and network ACL rules
In Figure 3, there is a subnet (Subnet-A) in VPC-A. Two ECSs (ECS-A and ECS-B) are running in this subnet. To protect your resources in VPC-A, you:
  • Associate a network ACL (Fw-A) with Subnet-A. The default rules in Fw-A cannot be deleted. Traffic preferentially matches your custom rules. Table 2 shows some example rules.
  • Create a security group Sg-A to protect ECS-A and ECS-B. When creating security group Sg-A, you can select an existing template. A template comes with some default rules. You can modify, delete default rules, and add custom rules. For details about security group rules, see Table 3.
Figure 3 How traffic matches security group and network ACL rules
Table 2 Rules in network ACL Fw-A
Direction
Rule Number
Type
Action
Protocol
Source
Source Port Range
Destination
Destination Port Range
Inbound
IPv4
Deny
All
10.0.1.0/24
All
0.0.0.0/0
All
Custom rule A01: denies traffic from 10.0.1.0/24 to the subnet.
Inbound
2
IPv4
Allow
TCP
0.0.0.0/0
All
0.0.0.0/0
80-85
Custom rule A02: allows all TCP traffic to the instances in the subnet over ports 80 to 85.
Inbound
Deny
All
0.0.0.0/0
All
0.0.0.0/0
All
Default rule: denies all inbound traffic to the subnet.
Outbound
IPv4
Allow
All
0.0.0.0/0
All
0.0.0.0/0
All
Custom rule A03: allows all outbound traffic from the subnet.
Outbound
Deny
All
0.0.0.0/0
All
0.0.0.0/0
All
Default rule: denies all outbound traffic from the subnet.
Table 3 Rules configured for security group Sg-A
Direction
Priority
Action
Type
Protocol & Port
Source/Destination
Inbound
Allow
IPv4
TCP: 80
Source: 0.0.0.0/0
Rule A01: allows all IPv4 traffic to the instances in the security group over port 80.
Inbound
Deny
IPv4
TCP: 82-83
Source: 0.0.0.0/0
Rule A02: denies all IPv4 traffic to the instances in the security group over ports 82 and 83.
Inbound
Allow
IPv4
All
Source: current security group (Sg-A)
Rule A03: allows the instances in the security group to communicate with each other using any IPv4 protocol and port.
Inbound
Allow
IPv6
All
Rule A04: allows the instances in the security group to communicate with each other using any IPv6 protocol and port.
Outbound
Allow
IPv4
All
Destination: 0.0.0.0/0
Rule A05: allows all IPv4 traffic from the instances in the security group.
Outbound
Allow
IPv6
All
Destination: ::/0
Rule A06: allows all IPv6 traffic from the instances in the security group.
Based on the preceding scenarios, different inbound packets match rules as follows:
  • Packet 01: If no custom rules in Fw-A are matched, the default rule is applied, denying packet 01 to the subnet.
  • Packet 02: If custom rule A01 in Fw-A is matched, this rule is applied, denying packet 02 to the subnet.
  • Packet 03: If custom rule A02 in Fw-A is matched, this rule is applied, allowing packet 03 to the subnet. Packet 03 continues to match the security group rules. If it does not match any inbound rule in Sg-A, packet 03 is denied to the instances.
  • Packet 04: If custom rule A02 in Fw-A is matched, this rule is applied, allowing packet 04 to the subnet. Packet 04 continues to match the security group rules. If it matches rule A02 in Sg-A, packet 04 is denied to the instances.
  • Packet 05: If custom rule A02 in Fw-A is matched, this rule is applied, allowing packet 05 to the subnet. Packet 05 continues to match the security group rules. If it matches rule A01 in Sg-A, packet 05 is allowed to the instances.
