Associating Subnets with a Network ACL
You can associate a subnet with a network ACL. If it is enabled, it controls traffic in and out of the subnet.
Associating subnets with a network ACL may affect how and where traffic is directed. Be careful with this operation as it may interrupt services.
- You can associate a network ACL with multiple subnets. However, a subnet can only be associated with one network ACL at a time.
 - After a network ACL is associated with a subnet, the default rules deny all traffic to and from the subnet until you add custom rules to allow traffic. For details, see Adding a Network ACL Rule.
- Go to the VPC list page.
 - Associate a subnet with a network ACL using either of the following methods:
- Method 1
- In the navigation pane on the left, click Subnets.
The Subnets page is displayed.
 - In the subnet list, locate the row that contains the subnet and click Associate under the Network ACL column.
The Associate Network ACL page is displayed.
 - Select a network ACL from the drop-down list.
If there is no network ACL, click
 in the drop-down list to create one. - Click OK.
The subnet list is displayed. You can view the associated network ACL of the subnet.
 - Method 2
- In the navigation pane on the left, choose Access Control > Network ACLs.
The network ACL list is displayed.
 - In the network ACL list, locate the target network ACL and click Associate Subnet in the Operation column.
The Associated Subnets tab is displayed.
 - On the Associated Subnets tab, click Associate.
The Associate Subnet dialog box is displayed.
 - In the Associate Subnet dialog box, select the subnet from the subnet list and click OK.
In the associated subnet list, you can view all subnets associated with the network ACL.
          A subnet with a network ACL associated will not be displayed in the subnet list of the Associate Subnet dialog box for you to select. If you want to associate such a subnet with another network ACL, you must first disassociate the subnet from the original network ACL.
 - Method 1
