Updated on 2026-11-04 GMT+08:00
Adding a Security Group Rule
A security group consists of inbound and outbound rules to control the traffic that is allowed to flow into or out of instances (such as ECSs) in the security group. Security group rules are commonly used to allow or deny network traffic from specific sources or over specific protocols, block certain ports, and define specific access permissions for instances.
You can add a security group rule using any of the following methods:
  • Adding Rules to a Security Group: You need to specify the action, priority, type, protocol, port, and source or destination of a security group rule as prompted.
  • Fast-Adding Multiple Security Group Rules: You can quickly add rules with common ports and protocols for remote logins, ping tests, common web services, and database services.
  • Allowing Common Ports with a Few Clicks: You can allow common ports with just a few clicks. This function can be used in the following scenarios:
    • Remote login to ECSs
    • Using the ping command to test ECS connectivity
    • ECSs functioning as web servers to provide website services accessible from an external network
Notes
Before adding a security group rule, note the following:
  • A security group has inbound and outbound rules to control traffic that is allowed to reach or leave the instances associated with the security group. For details about the rules, see What Are Security Group Rules?.
  • If an instance is associated with multiple security groups, the security group rules are matched by priority. For details about the matching sequence, see How Traffic Matches Security Group Rules.
  • The number of rules in a security group is limited. Keep only the rules you need. For details, see Constraints on Using Security Groups.
  • After allowing traffic over a port in a security group rule, you need to ensure that the port used by the instance is also opened. For details, see Checking Whether a Port Is Enabled on an ECS.
  • If the source is set to 0.0.0.0/0 or ::/0, then the access from all external IP addresses is either allowed or denied, depending on if the action is Allow or Deny. If the access is allowed, exposing high-risk ports, such as port 22, 3389, or 8848, to the public network will leave your instances vulnerable to network intrusions, causing service interruptions, data leakage, or ransomware attacks. You should only configure known IP addresses for the security group rule.
  • By default, instances in the same security group can communicate with each other. If instances in the same security group cannot communicate with each other, possible causes are as follows:
    • The instances are in the same VPC, but the inbound rules in the security group for communications between them are deleted. Table 1 shows the inbound rules.
      Table 1 Inbound rules for communications between instances in a security group
      Direction
      Priority
      Action
      Type
      Protocol & Port
      Source/Destination
      Inbound
      Allow
      IPv4
      All
      Source: current security group (Sg-A)
      Inbound
      Allow
      IPv6
      All
    • The instances are in the same security group but belong to different VPCs. Instances in different VPCs cannot communicate with each other.
      You can use VPC peering connections to connect different VPCs. For details, see VPC Peering Connection Overview.
Configuration Example
Before configuring security group rules, you need to plan access policies for instances in the security group.
  • If an instance needs to provide services for external networks, add an inbound rule to allow external requests to the instance.
  • If there are attacks to an instance from external networks, add an inbound rule to deny external requests that have security risks.
  • If an instance needs to access external networks, add an outbound rule to allow requests from the instance to external networks.
  • If you no longer need to control certain inbound or outbound traffic, you can delete the corresponding security group rules to simplify the rule configuration.
  • If you need to copy rules from other security groups, you can import and export security group rules or clone security groups. For details, see Migrating Security Groups Across Regions or Accounts.
Security Group Examples shows more security group rule configuration examples.
Adding Security Group Rules
  1. Go to the security group list page.
  2. Locate the target security group and click Manage Rules in the Operation column.
    The page for configuring security group rules is displayed.
  3. On the Inbound Rules tab, click Add Rule.
    The Add Inbound Rule dialog box is displayed.
  4. Configure inbound rule parameters as prompted. You can add multiple inbound rules one by one.
    Figure 1 Add Inbound Rule
    Table 2 Inbound rule parameter description
    Example Value
    Priority
    The security group rule priority.
    The priority value ranges from 1 to 100. The default value is 1, which has the highest priority. The security group rule with a smaller value has a higher priority.
    Action
    The value can be Allow or Deny.
    • If the Action is set to Allow, traffic is allowed to access the cloud servers in the security group over specified ports.
    • If the Action is set to Deny, traffic is denied to access the cloud servers in the security group over specified ports.
    Security group rules are matched first by priority and then by action. Deny rules take precedence over allow rules. For more information, see How Traffic Matches Security Group Rules.
    Allow
    Type
    Source IP address version. You can select:
    • IPv4
    • IPv6
    IPv4
    Protocol & Port
    The network protocol used to match traffic in a security group rule. The protocol can be All, TCP, UDP, GRE, or ICMP.
    TCP
    Destination port used to match traffic in a security group rule. The value can be from 1 to 65535.
    Inbound rules control incoming traffic over specific ports to instances in the security group.
    Enter ports in any of the following formats:
    • Individual port: Enter a port, such as 22.
    • Consecutive ports: Enter a port range, such as 22-30.
    • Non-consecutive ports: Enter ports and port ranges, such as 22,23-30. You can enter a maximum of 20 ports and port ranges. Each port range must be unique.
    • All ports: Leave it empty or enter 1-65535.
    22, 22-30
    Source
    Used to match the source of an external request. The source can be:
    • IP address: The source is a fixed IP address. You can enter or paste multiple IP addresses separated by commas (,). Each IP address represents a different security group rule.
      • Single IP address: IP address/mask
        Example IPv4 address: 192.168.10.10/32
        Example IPv6 address: 2002:50::44/128
      • IP address range in CIDR notation: IP address/mask
        Example IPv4 address range: 192.168.52.0/24
        Example IPv6 address range: 2407:c080:802:469::/64
      • Any IP addresses
        0.0.0.0/0 represents all IPv4 addresses.
        ::/0 represents all IPv6 addresses.
    • Security group: The source is from another security group. You can select a security group in the same region from the drop-down list. If there is instance A in security group A and instance B in security group B, and the inbound rule of security group A allows traffic from security group B, traffic is allowed from instance B to instance A.
    • IP address group: The source is from an IP address group. An IP address group is a set of one or more IP addresses. You can select an available IP address group from the drop-down list. For IP address ranges and IP addresses with the same security requirements, you can use an IP address group to simplify management.
      If no IP address groups are available, create one by referring to Creating an IP Address Group.
    IP address:
    192.168.52.0/24,10.0.0.0/24
    (Optional) Supplementary information about the security group rule.
    The security group rule description can contain a maximum of 255 characters and cannot contain angle brackets (< or >).
    N/A
  5. Click OK.
    The inbound rule list is displayed.
  6. On the Outbound Rules tab, click Add Rule.
    The Add Outbound Rule dialog box is displayed.
  7. Configure outbound rule parameters as prompted. You can add multiple outbound rules one by one.
    Figure 2 Add Outbound Rule
    Table 3 Outbound rule parameter description
    Example Value
    Priority
    Action
    • If the Action is set to Allow, access from ECSs in the security group is allowed to the destination over specified ports.
    • If the Action is set to Deny, access from ECSs in the security group is denied to the destination over specified ports.
    Allow
    Type
    Destination IP address version. You can select:
    • IPv4
    • IPv6
    IPv4
    Protocol & Port
    TCP
    Outbound rules control outgoing traffic over specific ports from instances in the security group.
    22, 22-30
    Destination
    Used to match the destination of an internal request. The destination can be:
    • IP address: The destination is a fixed IP address. You can enter or paste multiple IP addresses separated by commas (,). Each IP address represents a different security group rule.
      • Any IP addresses
    • Security group: The destination is another security group. You can select a security group in the same region under the current account from the drop-down list. If there is instance A in security group A and instance B in security group B, and the outbound rule of security group A allows traffic to security group B, traffic is allowed from instance A to instance B.
    • IP address group: The destination is in an IP address group. An IP address group is a set of one or more IP addresses. You can select an available IP address group from the drop-down list. For IP address ranges and IP addresses with the same security requirements, you can use an IP address group to simplify management.
    IP address:
    N/A
  8. Click OK.
    The outbound rule list is displayed.
  3. On the Inbound Rules tab, click Fast-Add Rule.
    The Fast-Add Inbound Rule dialog box is displayed.
    Figure 3 Fast-Add Inbound Rule
    Table 4 Inbound rule parameter description
    Example Value
    Protocols and Ports
    Common protocols and ports are provided for:
    • Remote login and ping
    • Web service
    • Database
    SSH (22)
    Type
    • IPv4
    • IPv6
    IPv4
    Source
      • Any IP addresses
    IP address:
    Action
    Allow
    Priority
    N/A
  5. Click OK.
    The inbound rule list is displayed and you can view your added rule.
  6. On the Outbound Rules tab, click Fast-Add Rule.
    The Fast-Add Outbound Rule dialog box is displayed.
    Figure 4 Fast-Add Outbound Rule
    Table 5 Outbound rule parameter description
    Example Value
    Protocols and Ports
    • Web service
    • Database
    SSH (22)
    Type
    • IPv4
    • IPv6
    IPv4
    Destination
      • Any IP addresses
    IP address:
    Priority
    Action
    Allow
    N/A
  8. Click OK.
    The outbound rule list is displayed and you can view your added rule.
  2. Locate the target security group and click its name.
    The security group details page is displayed.
  3. Click the Inbound Rules or Outbound Rules tab as required, and then click Allow Common Ports.
    The Allow Common Ports page is displayed.
    Table 6 describes the common ports that can be opened with a few clicks.
    Table 6 Common ports
    Direction
    Protocol & Port & Type
    Source/Destination
    Inbound
    TCP: 22 (IPv4)
    0.0.0.0/0
    Allows all IPv4 addresses to access ECSs in the security group over port 22 (SSH) for remotely logging in to Linux ECSs.
    TCP: 3389 (IPv4)
    0.0.0.0/0
    Allows all IPv4 addresses to access ECSs in the security group over port 3389 (RDP) for remotely logging in to Windows ECSs.
    TCP: 80 (IPv4)
    0.0.0.0/0
    Allows all IPv4 addresses to access ECSs in the security group over port 80 (HTTP) for visiting websites.
    TCP: 443 (IPv4)
    0.0.0.0/0
    Allows all IPv4 addresses to access ECSs in the security group over port 443 (HTTPS) for visiting websites.
    TCP: 20-21 (IPv4)
    0.0.0.0/0
    Allows all IPv4 addresses to access ECSs in the security group over ports 20 and 21 (FTP) for uploading or downloading files.
    ICMP: All (IPv4)
    0.0.0.0/0
    Allows all IPv4 addresses to access ECSs in the security group over any port for connectivity testing using the ping command.
    Outbound
    All (IPv4)
    All (IPv6)
    0.0.0.0/0
    ::/0
    Allows access from ECSs in the security group to any IP address over any port.
  4. Click OK.
    After the operation is complete, you can view the added rules in the security group rule list.
For example, if you have deployed a website on an ECS and want users to access your website through HTTP (80), you need to add an inbound rule to the ECS security group to allow access over the port. Table 7 shows the rule.
Table 7 Security group rule
Direction
Priority
Action
Type
Protocol & Port
Source
Inbound
Allow
IPv4
TCP: 80
IP address: 0.0.0.0/0
After adding the security group rule, perform the following operations to check whether the ECS port is opened and whether the rule is applied:
  1. Log in to the ECS and check whether the ECS port is enabled.
    • Checking a Linux ECS port
      Run the following command to check whether TCP port 80 is being listened on:
      netstat -an | grep 80
      If the following figure is displayed, TCP port 80 is enabled.
      Figure 5 Command output for the Linux ECS
    • Checking a Windows ECS port
      1. Choose Start > Run. Type cmd to open the Command Prompt.
      2. Run the following command to check whether TCP port 80 is being listened on:
        netstat -an | findstr 80
        Figure 6 Command output for the Windows ECS
  2. Enter http://ECS EIP in the address box of the browser and press Enter.
    If the requested page can be accessed, the security group rule has taken effect.
