Deleting a VPC Flow Log
You can delete a VPC flow log if you no longer need it. Deleting a VPC flow log will not delete the existing flow log records in LTS.
If a network interface that uses a VPC flow log is deleted, the flow log is automatically deleted. However, the flow log records are not deleted.
- Go to the VPC flow log list page.
- Locate the target flow log and click Delete in the Operation column.
A confirmation dialog box is displayed.
- Confirm the information and click OK.
