Help Center/
      Database and Application Migration UGO/
        User Guide/
        Error Codes/
        SQL Audit Errors/
      UGO.10100011 Failed to connect to Kafka
        Updated on 2025-10-22 GMT+08:00
The connection to Kafka is abnormal.
Possible Causes
The Kafka connection information is incorrect.
Handling Suggestion
- Check whether connection information such as the IP address, port number, topic name, login username, and login password is correct.
 - Check whether the network connection is limited.
 - Take a screenshot of the error.
 - In the upper right corner of the console, choose Service Tickets > Create Service Ticket and contact the customer service.
   Parent topic: SQL Audit Errors
