Help Center/
      Database and Application Migration UGO/
        User Guide/
        Error Codes/
        Collection Errors/
      UGO.10010008 No object is collected in the target database
        Updated on 2025-06-07 GMT+08:00
No object is collected in the target database.
Possible Causes
The selected target database does not contain objects or the selected user does not have the read privilege.
Handling Suggestion
- Check whether the selected schema contains objects.
- Check whether the selected user has the privilege to query the selected schema.
   Parent topic: Collection Errors
