Re-evaluating a Project
The Project Status of an evaluation project is In progress. Confirm Target DB Pending.
Frozen accounts cannot re-evaluate objects.
This function is not available for Microsoft SQL Server databases.
You can re-evaluate the information of your project, including dynamic SQL statements, workloads, object conversion, top incompatible syntax points, and system objects.
- Log in to the UGO console.
- In the navigation pane, choose .
- In the evaluation project task list, select the project to be analyzed and choose More > Re-Evaluate in the Operation column.
- (If the source database type is Oracle) In the displayed box, click Edit and configure Dynamic SQL Evaluation.
- Yes: The dynamic SQL statements in objects are analyzed.
- No: The dynamic SQL statements are not analyzed.
- Click OK.
- Project Status of the evaluation project is In progress. The detailed project status and progress are also displayed.
- To stop or resume the re-evaluation, click Stop or Resume.
